mk2 GTi brakes on mk3?
antnee
I thought they were the same as the 16v gti brakes anyway?
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
a bit offtopic. what size are the front brakes ona mk3 cupra?
280mm and 305mm on the Brembo's on the Cupra R
Ibiza125 - what size discs do you have at present ? just wanna check you have the right hubs thats all
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
I believe Sports are 256mm
i thought the same, just wanted to be sure it's a bolt on mod as the smaller 239mm has different hub/bearing carriers
in fact if it's lucas brakes (256) iirc all you need is the 280mm frame itself
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
smaller ones have the caliper mounting built in to the carrier whereas the 256/280 have a bolt on frame that the caliper then fits to
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
239 are a built in hub/frame
256 bolt in small diameter
280 bolt in large diameter
to convert 256-280 you'll need frames and discs for it to all line up
antnee
Flapper-whats the frame? Is it the caliper carriers or are the hubs already drilled for the calipers?
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
caliper carriers are held on to the hub 2 bolts then the caliper fits to that
ill post a pic up later
antnee
Sweet so I just need some cupra carriers then (or golf G60, etc)
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
difference in terminology that's all
wheel bearing housing on 239mm discs fits the caliper direct as the caliper carrier is built in (2 part)
256/280 is just a bearing housing on its own with a bolt on frames/carriers which the caliper then fits onto with slider pins (3 part)
if you have 256's (pretty sure it is but check) and get a 280 caliper set with frames/carriers it's a bolt on job
if you have 239's you'll need bearing housings from a 256/280 to go with it
send me an email and ill forward a pic to help ?
antnee
Bump for this thread. My mechanic said the brakes will need doing soon.
Flapper I sent you an email after your last post, but had no reply
