Mk1 seat Leon Cupra apy block ko4 turbo idle and boost issues
cf22cupra
cf22cupra
Apr 29, 2013
16
West yorkshire
Hi guys
I've got issues with my car at the moment and in need of some help. I've had a lot swapped recently and had the problems since the engine change
I'm not over my 15posts yet so I can't upload any pictures at the moment so I will do my best to describe it and give as much info as possible.
I've had a look on the forum for anything with similar symptoms but with me not knowing what my problem is it's hard to know if it's already been covered and I apologise in advance if it has.
So I have a 2002 seat Leon Cupra 1.8t (ko4 s3 apy block)
Epc warning lamp on (constant doesn't go off even clearing codes)
Revs drop when I come out of gear coming up to lights,junctions it drops to 500rpm battery light flashes then it idles fine(odd occasion it cuts out when it drops)
It seems to hold boost if you put your foot down in lower gears and holds boost fine but If I put it in 3rd or above at the average speed for each gear I put my foot it seems to be hesitant (whistle/screech like a intercooler hose leak between 15-22psi) hits 22 psi then drops back down to 13psi then it feels flat until I let off and back on the accelerator.
My mpg is rediculous. I brimmed it yesterday and my trip only said 170 miles to £67. Did 3/4 of a tank in doing a 120 mile motorway run 70-75 all the way and stuck in abit of traffic for half hour
Fault codes :
18084-epc warning lamp(k132) circuit electrical malfunction
P 1676 35-10 intermittent
17931-crash sensor from airbag controller implausible signal
P 1523 35-10 intermittent
^^^^*could theses be linked to my issues or could the airbag controller cause the epc (if so what should I look for and where ^^^^^^^^
So far I have checked or replaced since the problem started
Maf replaced
Crankshaft postion sensor replaced
Throttle body replaced (tried 3 used ones )
Wastegate checked
Re sealed the billet on the tip
Changed spark plugs
Changed fuel filter
Replaced all rubber hoses clips and clamps throughout apart from coolant pipes
I made a contraption today to test for leaks between turbo and inlet while the engine was swiched off as I had a suspicion it was my intercooler pipes
I put I bung in the intake hose(throttle body hose) and in the 90deg hose of the turbo,disconnected the n75 pipe off the charge pipe and fitted a tyre valve in place,I then pressurised it and it would only go to 7psi,I also noticed a hissing from the airfilter so I disconnected the divertor valve from the tip and it was this leaking the air (forge 007p revised piston just service with yellow spring )
I did the same test again but took the dv out and bunged the pipe up (charge pipe to dv) and it went up to 25psi and held there for 10 minutes so I know there's no boost leaks. So is the divertor valve causing my problems? I've heard the vacuum pipe helps to keep it closed when your in boost so it wouldn't open at 7psi like it does with the engine off but I'm unsure of that.
Here's a list of parts been fitted to save having to ask for info if it's needed. I'm unsure of who mapped the ecu too,also I was told my current fuel pump was ok for what I've had done but I'm abit unsure
All in all it's had
Complete apy engine 122k fsh including engine loom and mapped immo off ecu (could this cause epc?)
Reconditioned ko4-22 turbo
Reconditioned 6 speed box
New LUK fly wheel
New LUK clutch kit
Relentless downpipe
Toyo intercooler (600x300)
Cobra resonated catback
Saukimichi catch tank
Oversized billet tip
Sai removed
N112 removed
N249 removed
All hoses are new
Any hints tips or anything that I havnt mentioned already would be a massive help as I'm just spend on bits I don't need I don't really know what else to put it down to other than a poorly refurbished turbo(to explain the sound over 13-16psi), ecu related either from de immo or generic/poor map ,faulty divertor valve(unsure of this with the comment I mentioned erlea).
Cheers for reading and again any info or ideas will be appreciated :D
mty12345
3,907
538
bristol
The airbag sensor is mounted to the floor under the seats, if you've had wet carpets from the leaky door seals, then i've seen lots of cases on here where water has caused that fault code.
The EPC code is strange, seems to relate to the light itself rather than the throttle body. Have you reset the throttle with VCDS/vagcom? I'm not sure if that would cause that code, but worth a try if you haven't already done so.
http://wiki.ross-tech.com/wiki/index.php/18084/P1676/005750
I'll have a think about your boost issues and get back to you if i think of anything, nothing jumps out at me though.
cf22cupra
cf22cupra
Apr 29, 2013
16
West yorkshire
I have yes altho the second one I fitted I forgot and it made no difrence . Cheers il take my seats out tomorow and see if there's any water under there .
The epc is annoying me abit but it's the boost cutting after hitting full boost and turbo noise that I've been concentrating on but I thought could the boost issues cause the epc to come on ,Some have said epc is on because it's got decat some have said throttle noddy and clutch switch and the lad who did the work thinks it's because I've gone from wideband to narrowband he only changed the engine loom.so I'm abit stumpedas I've checked all I know. I have vagcom but I'm yet to learn how to do logs and understand it all
mty12345
3,907
538
bristol
Right mate, no the EPC light is purely related to the throttle body and drive by wire system, so i'd say 100% that is unrelated to any other engine or cat problem.
It's the "check engine" (far right hand side,middle row) light that relates to any engine problems, but even then it will only come on if it's a fault that will raise your emmisions etc.
As for logging on vagcom, you connect to the engine module on the vagcom menu, then select "meas blocks" on the left hand side menu. You'll then see a screen where you can enter a 3 digit number, Just enter 000 then keep clicking the up arrow to scroll through all the avalible sensors that you can measure.
There is space to enter 3 different codes, so you can log 3 different things at once if needed. For example "115" will show you actual boost vs requested boost from the ECU, this would probably be very useful for you.
To save a log file, once you've selected the group/s to log, you just click on "log" at the bottom of the menu and choose somewhere to save the log on your laptop. Then click on "start" and then you can start driving etc and the log will be saved for you to view later on.
mty12345
3,907
538
bristol
I'd say log group 115 and group 031 and 032 for starters. 031 and 032 are your lambda readings from memory.(if i'm wrong then they are close to that, maybe 030 or something) If the engine is seeing a lean mixture it's quite possible that it's pulling your boost back as a safety measure.
If you upload the logs of those groups then someone on here will look them over for you and we'll go from there buddy.
cf22cupra
cf22cupra
Apr 29, 2013
16
West yorkshire
cheers for that info bud , I will get a few logs done and post the results up. I wonder if it could be a broken wire with it bieng removed from a 16 year old car .I've checked all fuses in the dash and replaced all the relays behind the drivers dash pannel and also the two in in the box in the engine bay also clean the surfaces on ground points anyway il get logs up and that will hopefully give more ideas of the problems
cf22cupra
cf22cupra
Apr 29, 2013
16
West yorkshire
1ST RUN
8L0 906 018 K ,,1.8L R4/5VT 0004,
,Group A:,'115,,,,Group B:,'032,,,,Group C:,'031
,,RPM,Load,Absolute Pres.,Absolute Pres.,,Lambda,Lambda,Bin. Bits,Bin. Bits,,Voltage,Bin. Bits,Bin. Bits,Bin. Bits
,TIME,,,,,TIME,,,,,TIME,,,,
MARKER,STAMP, /min,%, mbar, mbar,STAMP,%,%,,,STAMP, V,,,
,0.02,840,15.0,1000.0,1010.0,0.62,0.0,0.0, , ,1.26,0.785, , ,
,1.93,1040,46.6,1000.0,1010.0,2.62,0.0,0.0, , ,3.23,0.735, , ,
,3.79,1720,44.4,1000.0,1040.0,4.34,0.0,0.0, , ,4.89,0.790, , ,
,5.43,3360,90.2,1000.0,1420.0,6.09,0.0,0.0, , ,6.70,0.670, , ,
,7.35,4760,9.8,1000.0,1260.0,8.00,0.0,0.0, , ,8.62,0.855, , ,
,9.23,4240,162.4,1780.0,2220.0,9.92,0.0,0.0, , ,10.48,0.050, , ,
,11.04,2880,6.0,1000.0,1060.0,11.59,0.0,0.0, , ,12.17,0.015, , ,
,12.78,2440,12.8,1000.0,1030.0,13.37,0.0,0.0, , ,14.03,0.010, , ,
,14.71,1520,14.3,1000.0,1020.0,15.33,0.0,0.0, , ,15.92,0.800, , ,
,16.60,1280,52.6,1080.0,1010.0,17.32,0.0,0.0, , ,18.04,0.760, , ,
,18.73,1720,74.4,1380.0,1190.0,19.29,0.0,0.0, , ,19.85,0.770, , ,
,20.43,2400,127.8,1980.0,1520.0,20.99,0.0,0.0, , ,21.51,0.830, , ,
,22.12,3320,157.9,1720.0,2120.0,22.73,0.0,0.0, , ,23.34,0.840, , ,
,24.01,4560,173.7,1770.0,2290.0,24.70,0.0,0.0, , ,25.26,0.650, , ,
,25.84,3920,154.9,1820.0,1410.0,26.40,0.0,0.0, , ,26.96,0.035, , ,
,27.54,3160,6.0,1000.0,1060.0,28.18,0.0,0.0, , ,28.82,0.015, , ,
,29.49,2320,14.3,1000.0,1030.0,30.10,0.0,0.0, , ,30.70,0.010, , ,
,31.26,2120,11.3,1000.0,1020.0,31.78,0.0,0.0, , ,32.31,0.010, , ,
,32.94,2000,9.0,1000.0,1020.0,33.56,0.0,0.0, , ,34.18,0.005, , ,
,34.82,1880,7.5,1000.0,1020.0,35.51,0.0,0.0, , ,36.12,0.035, , ,
,36.82,1840,9.8,1000.0,1020.0,37.49,0.0,0.0, , ,38.12,0.070, , ,
,38.82,1800,9.0,1000.0,1010.0,39.54,0.0,0.0, , ,40.21,0.000, , ,
,40.92,1760,10.5,1000.0,1020.0,41.57,0.0,0.0, , ,42.20,0.005, , ,
,42.79,1720,9.8,1000.0,1020.0,43.35,0.0,0.0, , ,43.89,0.005, , ,
,44.55,1480,9.8,1000.0,1020.0,45.07,0.0,0.0, , ,45.67,0.090, , ,
,46.28,1080,12.0,1000.0,1010.0,46.92,0.0,0.0, , ,47.59,0.060, , ,
,48.21,840,17.3,1000.0,1010.0,48.92,0.0,0.0, , ,49.59,0.055, , ,
,50.21,840,18.0,1000.0,1010.0,50.89,0.0,0.0, , ,51.63,0.055, , ,
,52.31,840,17.3,1000.0,1010.0,53.01,0.0,0.0, , ,53.62,0.055, , ,
,54.29,840,17.3,1000.0,1010.0,54.90,0.0,0.0, , ,55.46,0.055, , ,
,55.99,840,17.3,1000.0,1010.0,56.57,0.0,0.0, , ,57.17,0.055, , ,
,57.74,1160,33.8,1000.0,1010.0,58.37,0.0,0.0, , ,58.98,0.705, , ,
,59.59,1240,30.1,1000.0,1010.0,60.15,0.0,0.0, , ,60.70,0.060, , ,
,61.29,1560,15.8,1000.0,1010.0,61.87,0.0,0.0, , ,62.49,0.055, , ,
,63.14,1640,18.8,1000.0,1010.0,63.77,0.0,0.0, , ,64.38,0.060, , ,
,65.00,1440,21.1,1000.0,1010.0,65.56,0.0,0.0, , ,66.10,0.650, , ,
,66.70,1520,31.6,1000.0,1020.0,67.26,0.0,0.0, , ,67.82,0.735, , ,
,68.46,2080,47.4,1000.0,1040.0,69.09,0.0,0.0, , ,69.71,0.785, , ,
,70.42,3640,75.9,1010.0,1400.0,71.07,0.0,0.0, , ,71.71,0.815, , ,
,72.40,3000,100.0,2140.0,1110.0,72.96,0.0,0.0, , ,73.51,0.845, , ,
,74.10,3760,21.8,1000.0,1360.0,74.65,0.0,0.0, , ,75.23,0.835, , ,
,75.85,3440,191.7,2330.0,2320.0,76.48,0.0,0.0, , ,77.10,0.845, , ,
,77.79,3760,6.8,1000.0,1230.0,78.48,0.0,0.0, , ,79.09,0.875, , ,
,79.65,3560,191.7,2060.0,2420.0,80.21,0.0,0.0, , ,80.76,0.725, , ,
,81.34,3200,5.3,1000.0,1070.0,81.90,0.0,0.0, , ,82.56,0.015, , ,
,83.17,2560,10.5,1000.0,1030.0,83.77,0.0,0.0, , ,84.32,0.010, , ,
,84.89,2160,9.0,1000.0,1020.0,85.46,0.0,0.0, , ,86.06,0.010, , ,
,86.70,1920,6.0,1000.0,1020.0,87.32,0.0,0.0, , ,87.91,0.800, , ,
,88.57,1960,94.7,1570.0,1180.0,89.18,0.0,0.0, , ,89.74,0.775, , ,
,90.29,2280,132.3,2400.0,1620.0,90.87,0.0,0.0, , ,91.46,0.825, , ,
,92.07,2800,191.7,1540.0,2390.0,92.71,0.0,0.0, , ,93.31,0.730, , ,
,93.89,2440,6.0,1000.0,1070.0,94.59,0.0,0.0, , ,95.26,0.005, , ,
,95.87,1920,13.5,1000.0,1020.0,96.43,0.0,0.0, , ,96.99,0.005, , ,
,97.54,1680,9.8,1000.0,1020.0,98.09,0.0,0.0, , ,98.70,0.755, , ,
,122.78,1480,33.8,1000.0,1020.0,123.46,0.0,0.0, , ,124.06,0.725, , ,
,124.62,2080,87.2,1160.0,1170.0,125.21,0.0,0.0, , ,125.76,0.725, , ,
,126.32,2600,15.8,1000.0,1140.0,126.90,0.0,0.0, , ,127.49,0.010, , ,
,128.17,1960,17.3,1000.0,1030.0,128.85,0.0,0.0, , ,129.46,0.615, , ,
,130.06,880,30.1,1000.0,1010.0,130.75,0.0,0.0, , ,131.31,0.090, , ,
,131.87,880,18.8,1000.0,1010.0,132.50,0.0,0.0, , ,133.01,0.075, , ,
,133.59,840,19.5,1000.0,1010.0,134.23,0.0,0.0, , ,134.85,0.070, , ,
,135.56,1880,58.6,1000.0,1000.0,136.18,0.0,0.0, , ,136.87,0.785, , ,
,137.46,1680,43.6,1000.0,1040.0,138.16,0.0,0.0, , ,138.87,0.770, , ,
,139.54,3640,113.5,1070.0,1410.0,140.15,0.0,0.0, , ,140.71,0.790, , ,
,141.25,3240,141.4,1800.0,1470.0,141.84,0.0,0.0, , ,142.43,0.710, , ,
,143.01,3360,108.3,1600.0,1150.0,143.63,0.0,0.0, , ,144.24,0.830, , ,
,144.84,3840,18.0,1000.0,1770.0,145.40,0.0,0.0, , ,145.95,0.880, , ,
,146.56,3720,191.7,2040.0,2440.0,147.12,0.0,0.0, , ,147.71,0.865, , ,
,148.35,4080,18.0,1000.0,1380.0,148.96,0.0,0.0, , ,149.55,0.025, , ,
,150.24,3240,6.0,1000.0,1040.0,150.96,0.0,0.0, , ,151.63,0.015, , ,
,152.24,2640,7.5,1000.0,1030.0,152.96,0.0,0.0, , ,153.68,0.010, , ,
,154.35,2280,8.3,1000.0,1020.0,155.05,0.0,0.0, , ,155.71,0.010, , ,
,156.34,2200,8.3,1000.0,1020.0,156.95,0.0,0.0, , ,157.49,0.785, , ,
,158.06,2520,104.5,1420.0,1320.0,158.65,0.0,0.0, , ,159.23,0.070, , ,
,159.87,3000,111.3,1480.0,1520.0,160.49,0.0,0.0, , ,161.10,0.785, , ,
,161.73,3280,6.8,1000.0,1140.0,162.35,0.0,0.0, , ,163.03,0.010, , ,
,163.62,2760,12.8,1000.0,1040.0,164.16,0.0,0.0, , ,164.73,0.005, , ,
,165.31,2280,12.8,1000.0,1030.0,165.88,0.0,0.0, , ,166.51,0.005, , ,
I hope this helps although this the first log ive done so im unsure if its correct, i notice afte i fnished the log it would only give me 5psi boost and i also have more fault codes that i will postup , sorry for how ths is shown there was no other way fo me to upload to the site,cheers
cf22cupra
cf22cupra
Apr 29, 2013
16
West yorkshire
,Group A:,'115,,,,Group B:,'031,,,,Group C:,'032
,,RPM,Load,Absolute Pres.,Absolute Pres.,,Voltage,Bin. Bits,Bin. Bits,Bin. Bits,,Lambda,Lambda,Bin. Bits,Bin. Bits
MARKER,STAMP, /min,%, mbar, mbar,STAMP, V,,,,STAMP,%,%,,
,0.65,840,18.8,1010.0,1010.0,1.26,0.055, , , ,0.02,0.0,0.0, ,
,2.55,840,18.8,1010.0,1010.0,3.10,0.055, , , ,1.85,0.0,0.0, ,
,4.26,1560,16.5,1010.0,1010.0,4.82,0.050, , , ,3.68,0.0,0.0, ,
,6.01,760,36.8,1010.0,1020.0,6.65,0.825, , , ,5.40,0.0,0.0, ,
,7.98,1040,30.1,1010.0,1020.0,8.67,0.595, , , ,7.35,0.0,0.0, ,
,9.98,1400,43.6,1010.0,1030.0,10.67,0.575, , , ,9.26,0.0,0.0, ,
,11.95,2080,78.2,1110.0,1090.0,12.51,0.805, , , ,11.35,0.0,0.0, ,
,13.64,1520,78.9,1330.0,1070.0,14.23,0.775, , , ,13.06,0.0,0.0, ,
,15.49,2440,109.8,1930.0,1350.0,16.14,0.795, , , ,14.87,0.0,0.0, ,
,17.35,2000,81.2,1370.0,1090.0,18.07,0.765, , , ,16.73,0.0,0.0, ,
,19.20,2480,117.3,1020.0,1500.0,19.71,0.845, , , ,18.63,0.0,0.0, ,
,20.89,1840,7.5,1000.0,1040.0,21.51,0.030, , , ,20.24,0.0,0.0, ,
,22.71,1720,9.0,1000.0,1020.0,23.32,0.720, , , ,22.13,0.0,0.0, ,
,24.42,1680,30.1,1000.0,1020.0,24.95,0.090, , , ,23.88,0.0,0.0, ,
,26.21,1600,9.0,1000.0,1030.0,26.85,0.030, , , ,25.57,0.0,0.0, ,
,28.13,880,14.3,1000.0,1020.0,28.73,0.060, , , ,27.52,0.0,0.0, ,
,29.84,840,17.3,1000.0,1010.0,30.42,0.055, , , ,29.29,0.0,0.0, ,
,31.59,840,18.0,1000.0,1010.0,32.21,0.055, , , ,31.01,0.0,0.0, ,
,33.54,840,18.0,1000.0,1010.0,34.15,0.055, , , ,32.85,0.0,0.0, ,
,35.54,840,18.8,1000.0,1010.0,36.15,0.055, , , ,34.85,0.0,0.0, ,
,37.54,840,18.8,1000.0,1010.0,38.15,0.055, , , ,36.85,0.0,0.0, ,
,39.51,840,18.8,1000.0,1010.0,40.10,0.055, , , ,38.87,0.0,0.0, ,
,41.20,840,18.0,1000.0,1010.0,41.73,0.050, , , ,40.67,0.0,0.0, ,
,42.99,840,18.0,1000.0,1010.0,43.63,0.050, , , ,42.36,0.0,0.0, ,
,44.92,1160,24.8,1000.0,1020.0,45.53,0.825, , , ,44.31,0.0,0.0, ,
,46.63,1400,58.6,1000.0,1060.0,47.20,0.650, , , ,46.07,0.0,0.0, ,
,48.38,2800,49.6,1000.0,1190.0,49.02,0.325, , , ,47.76,0.0,0.0, ,
,50.34,2080,14.3,1000.0,1040.0,50.91,0.015, , , ,49.66,0.0,0.0, ,
,52.06,960,18.0,1000.0,1020.0,52.63,0.075, , , ,51.49,0.0,0.0, ,
,53.76,1000,48.1,1000.0,1020.0,54.40,0.110, , , ,53.17,0.0,0.0, ,
,55.74,2360,62.4,1000.0,1070.0,56.41,0.755, , , ,55.03,0.0,0.0, ,
,57.62,4400,22.6,1000.0,1530.0,58.21,0.805, , , ,56.99,0.0,0.0, ,
,59.47,4280,25.6,1000.0,2020.0,60.07,0.795, , , ,58.93,0.0,0.0, ,
,61.21,3160,7.5,1000.0,1060.0,61.85,0.025, , , ,60.62,0.0,0.0, ,
,63.03,1920,13.5,1000.0,1030.0,63.59,0.025, , , ,62.45,0.0,0.0, ,
,64.74,1560,9.0,1000.0,1020.0,65.29,0.025, , , ,64.15,0.0,0.0, ,
,66.49,1280,6.8,1000.0,1020.0,67.12,0.045, , , ,65.85,0.0,0.0, ,
,68.43,920,16.5,1000.0,1010.0,69.10,0.060, , , ,67.81,0.0,0.0, ,
,70.43,840,15.0,1000.0,1010.0,71.13,0.060, , , ,69.74,0.0,0.0, ,
,72.43,1400,29.3,1000.0,1010.0,73.13,0.795, , , ,71.81,0.0,0.0, ,
,74.42,1840,72.2,1100.0,1060.0,75.02,0.785, , , ,73.79,0.0,0.0, ,
,76.31,3120,12.0,1000.0,1140.0,76.85,0.820, , , ,75.71,0.0,0.0, ,
,77.95,2720,36.1,1000.0,1230.0,78.60,0.055, , , ,77.37,0.0,0.0, ,
,79.87,2840,24.1,1010.0,1040.0,80.51,0.665, , , ,79.26,0.0,0.0, ,
,81.82,2960,38.3,1010.0,1040.0,82.43,0.810, , , ,81.15,0.0,0.0, ,
,83.84,3040,16.5,1010.0,1100.0,84.52,0.810, , , ,83.12,0.0,0.0, ,
,85.81,2520,8.3,1010.0,1060.0,86.37,0.015, , , ,85.20,0.0,0.0, ,
,87.48,2360,10.5,1010.0,1030.0,88.02,0.010, , , ,86.93,0.0,0.0, ,
,89.29,2200,8.3,1010.0,1030.0,89.93,0.015, , , ,88.66,0.0,0.0, ,
,91.20,2120,20.3,1010.0,1020.0,91.81,0.705, , , ,90.62,0.0,0.0, ,
,93.21,2160,73.7,1020.0,1090.0,93.74,0.695, , , ,92.49,0.0,0.0, ,
,94.88,2480,9.8,1010.0,1150.0,95.48,0.025, , , ,94.31,0.0,0.0, ,
,96.67,2280,16.5,1010.0,1040.0,97.29,0.010, , , ,96.06,0.0,0.0, ,
,98.62,2080,8.3,1010.0,1030.0,99.31,0.010, , , ,97.93,0.0,0.0, ,
,100.59,1760,9.0,1010.0,1020.0,101.18,0.010, , , ,99.90,0.0,0.0, ,
,102.59,840,15.0,1010.0,1010.0,103.18,0.065, , , ,101.90,0.0,0.0, ,
,104.26,880,16.5,1010.0,1010.0,104.80,0.055, , , ,103.71,0.0,0.0, ,
,106.09,840,17.3,1010.0,1010.0,106.71,0.055, , , ,105.45,0.0,0.0, ,
,108.06,840,17.3,1010.0,1010.0,108.70,0.050, , , ,107.41,0.0,0.0, ,
,109.99,840,17.3,1010.0,1010.0,110.53,0.050, , , ,109.31,0.0,0.0, ,
,111.67,840,17.3,1010.0,1010.0,112.21,0.050, , , ,111.12,0.0,0.0, ,
,113.46,840,17.3,1010.0,1010.0,114.07,0.050, , , ,112.85,0.0,0.0, ,
,115.39,840,18.0,1010.0,1010.0,115.99,0.055, , , ,114.71,0.0,0.0, ,
,117.24,840,18.0,1010.0,1010.0,117.82,0.050, , , ,116.68,0.0,0.0, ,
,118.98,840,18.0,1010.0,1010.0,119.59,0.055, , , ,118.40,0.0,0.0, ,
,120.79,840,18.0,1010.0,1010.0,121.37,0.050, , , ,120.20,0.0,0.0, ,
,122.49,840,18.0,1010.0,1010.0,123.07,0.050, , , ,121.93,0.0,0.0, ,
,124.31,840,18.0,1010.0,1010.0,124.93,0.055, , , ,123.66,0.0,0.0, ,
,126.18,1320,52.6,1010.0,1010.0,126.77,0.645, , , ,125.54,0.0,0.0, ,
,127.87,920,28.6,1010.0,1020.0,128.48,0.060, , , ,127.34,0.0,0.0, ,
,129.63,1080,38.3,1010.0,1020.0,130.27,0.690, , , ,129.06,0.0,0.0, ,
,131.51,1080,18.8,1010.0,1020.0,132.21,0.785, , , ,130.85,0.0,0.0, ,
,133.59,1320,36.1,1010.0,1020.0,134.21,0.065, , , ,132.88,0.0,0.0, ,
,135.49,1440,28.6,1010.0,1020.0,136.21,0.075, , , ,134.90,0.0,0.0, ,
,137.46,1600,29.3,1010.0,1020.0,137.99,0.075, , , ,136.87,0.0,0.0, ,
,139.08,1920,76.7,1850.0,1020.0,139.71,0.790, , , ,138.55,0.0,0.0, ,
,140.99,3360,11.3,1010.0,1280.0,141.62,0.810, , , ,140.35,0.0,0.0, ,
,142.87,3520,191.7,2410.0,2150.0,143.43,0.710, , , ,142.27,0.0,0.0, ,
,144.45,2680,124.1,2200.0,1470.0,145.04,0.825, , , ,143.96,0.0,0.0, ,
,146.31,3520,121.8,1010.0,2510.0,146.99,0.555, , , ,145.68,0.0,0.0, ,
,148.29,2920,6.8,1010.0,1050.0,148.96,0.020, , , ,147.65,0.0,0.0, ,
,150.12,2040,12.8,1010.0,1030.0,150.67,0.020, , , ,149.56,0.0,0.0, ,
,151.81,1960,76.7,1530.0,1060.0,152.45,0.765, , , ,151.24,0.0,0.0, ,
,153.74,2600,136.1,2330.0,1630.0,154.37,0.830, , , ,153.07,0.0,0.0, ,
,155.54,3400,18.8,1010.0,1530.0,156.07,0.780, , , ,154.96,0.0,0.0, ,
,157.24,2560,10.5,1010.0,1040.0,157.80,0.015, , , ,156.66,0.0,0.0, ,
,159.09,1760,14.3,1010.0,1030.0,159.65,0.010, , , ,158.44,0.0,0.0, ,
,160.77,1480,15.0,1010.0,1020.0,161.34,0.240, , , ,160.21,0.0,0.0, ,
,162.52,1400,6.0,1010.0,1020.0,163.17,0.035, , , ,161.88,0.0,0.0, ,
,164.41,880,12.0,1000.0,1010.0,165.05,0.060, , , ,163.77,0.0,0.0, ,
,166.18,840,16.5,1000.0,1010.0,166.76,0.065, , , ,165.63,0.0,0.0, ,
,167.90,840,16.5,1000.0,1010.0,168.54,0.065, , , ,167.32,0.0,0.0, ,
,169.79,840,15.8,1000.0,1010.0,170.46,0.060, , , ,169.16,0.0,0.0, ,
,171.60,840,16.5,1000.0,1010.0,172.15,0.060, , , ,171.04,0.0,0.0, ,
,173.27,1320,33.1,1000.0,1010.0,173.91,0.735, , , ,172.73,0.0,0.0, ,
,175.26,1360,17.3,1000.0,1020.0,175.90,0.715, , , ,174.55,0.0,0.0, ,
,177.16,1960,28.6,1000.0,1040.0,177.73,0.710, , , ,176.55,0.0,0.0, ,
,178.88,2480,43.6,1000.0,1050.0,179.46,0.765, , , ,178.29,0.0,0.0, ,
,180.70,3920,92.5,1450.0,1360.0,181.32,0.480, , , ,180.05,0.0,0.0, ,
,182.55,3040,130.1,2190.0,1410.0,183.16,0.855, , , ,181.93,0.0,0.0, ,
,184.29,3240,14.3,1000.0,1150.0,184.84,0.815, , , ,183.73,0.0,0.0, ,
,186.03,3400,191.7,1940.0,2300.0,186.63,0.825, , , ,185.38,0.0,0.0, ,
,187.96,4280,19.5,1000.0,1850.0,188.54,0.065, , , ,187.29,0.0,0.0, ,
,189.85,3680,191.7,2050.0,2410.0,190.42,0.870, , , ,189.16,0.0,0.0, ,
,191.57,4120,105.3,1000.0,2510.0,192.15,0.635, , , ,190.99,0.0,0.0, ,
,193.37,3720,6.0,1000.0,1060.0,193.96,0.035, , , ,192.77,0.0,0.0, ,
,195.10,3440,7.5,1000.0,1030.0,195.66,0.810, , , ,194.54,0.0,0.0, ,
,196.83,3600,191.7,2120.0,2270.0,197.41,0.870, , , ,196.24,0.0,0.0, ,
,198.68,3840,6.8,1000.0,1380.0,199.33,0.045, , , ,198.05,0.0,0.0, ,
,200.48,2800,8.3,1000.0,1040.0,201.07,0.020, , , ,199.94,0.0,0.0, ,
mty12345
3,907
538
bristol
5psi means it's gone into limp mode for some reason mate. I'm not sure how to upload the logs in an easier to read format, sure someone else will chip in who knows better than me. Yeah post the fault codes up if you can, one of those must be the reason for it going into limp mode.
