mk1 leon door trim
hughes86
159
manchester
does anyone know how to remove the front and rear door trims on an 04 plate leon cupra tdi? as i am puttin new kenwood componants in, as ive only just got the car lol:D
jay87
290
3 screws at the bottom of the panel (torx T25 or T20)
screws under the door handle, you will need to kind of pull it off (butter knife) (2 gold philips screws)
and one screw on the side of the panel of the top half (T20 or T25)
then pull the panel from the bottom slowly and raise up, if it hasnt been taken off before it might be hard because its kinda been put on air tight with a seal
theres plugs you will need to remove, and the door handle clip (on a pully)
(Back ones are the same, just less screws and less plugs)
hope that helps
