mk 3 boot lid
r1k1
heyy im knew to this im just wondering would a mk 3 boot lid fit on the mk 2? and does anyone know where i can get hold of a cheap spoiler for the mk 2??:D:D
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
it will bolt on at the top yes BUT you will also need the rear panel sides welded in from a mk3 top match as it curves inwards instead of straight down making the whole gap a different shape so not impossible to convert though but not a 5 min bolt on job
spoiler wise checkout the classifieds as there is a few GTI being broken up lately
r1k1
cheers for that was going to put a mk 3 lid on to save smoothin the mk 2 off but think itd be simpler to get the good old welder out instead
r1k1
true true its going to take alota work on that car anyways kus its the 5 door model and its only a 1.4 se
r1k1
alsso i lowerd it around 40 mm the other day and since then on the drivers front strut it squeaks like mad any ideas??
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
strut top mount in the wrong way up ?
how did you lower it ? coilovers are usually noisy mind
r1k1
just new springs on the old struts its weird its only the one side that makes the noise .... but both strut tops look like their on the same
r1k1
i dont think it is.. im going to strip it down and have a look tomorrow . i think the strut might be bent to be hones because it always looks lower on that side
CraigW
Craig.
Apr 12, 2007
4,607
Hawick, Scottish Borders, Scotland
There a couple of spoilers listed on ebay, with or without brake light and in primer for 20 odd quid plus 10 quid delivery.
Hope that helps.
Flapper, I know what you mean about the coilovers being noisey, fitted some on mine in July and they make more noise than my fixed lowering kit did.
