Missfire/Power loss @ 4500-5500 revs
illusion
91
Southampton
Hello all.
I have a 2000 plate Cupra which has a problem around the 4500-5500 revs mark.
When you reach about 4500rpm it kinda feels like a misfire and you get a definite loss of power but seems to clear after 5500rpm
It only seems to happen in 3rd - 6th.
I has been fully serviced from new by Seat, if that is important :), and has 77000 miles. Also I only ever run it on Shell Optimax.
Anybody have any ideas?
illusion
91
Southampton
I would guess so, but I don't have a boost gauge to be sure, but it is certainly happening when I am...ahm....pressing on shall we say :)
By dv do you mean dump valve?
lewis1984
I had the same problem with my 77000 fully serviced cupra. No codes came up on the vagcom. I changed the coils and cleaned the throttle body and i havent had a judder or miss-fire since.
Might be worth a try.
illusion
91
Southampton
Thanks for all the info gents.
Think I may start with the coil packs, then upgrade the DV.
I assume that the forge 007p DV will make a better tssssh sound (technical i know :rolleyes: )
