missfire 8v gti
Fin
hi, my gti has an intermittent missfire
sometimes the car starts up fine and drives really well :)
and other times it will start up, but if i try to pull away or accellerate it will bog down and missfire alot. This can be really embarrasing because it sounds terrible and its really under powered when its like this :cry:
but if leave it half an hour and try again it all ok again :confused:
has anyone else had this problem?
-=Rob=-
Beer or Car?
Dec 14, 2002
1,492
South West
Also check the plug leads, I had a misfire on an Ibiza 8v Gti I used to own, it turned out to be themetal cover on the lead arcing on the engine block, there was a really tiny split in the lead end which caused the cover to arc out....
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
check cap and rotor arm
might be worth a fuel filter change as i bet you cant say when the last one was fitted ?
Fin
i replaced the rotor arm, dizzy cap and leads about 2 months ago.....
i will change the filter when i next get a chance
90 spec 16v
check plug leads resistance using a multimeter and condition
