so I got a Ibiza 1.4 8v and when it rained heavily i got a misfire. I replaced spark plugs which were shot at and all seemed ok. A month later it started to misfire again in the rain only this time it is permanent now, even in dry.
plug leads, or supply of spark? another shot plug due to not resolving source of original problem?
Is it one particular plug? You could remove them one at a time, until you find the one that doesn't change the engine note or cause it to stall when it's not connected.
I don't think is spark plug I've had them all out again and they look ok. With it initiating when its raining hard water is obviously getting in somewhere. I wonder if the spark plug leads are the next port of call, maybe coil pack I guess
