My GFs Leon 1.8t has just begun misfireing when accelerating, engine management light is flashing. Car is juddering under load and smells odd, like its very hot? Just run VAGCOM and the following has come back:
VAG-COM Version: Release 311.2-N
Control Module Part Number: 06A 906 032 HN
Component and/or Version: 1.8L R4/5VT 0002
Software Coding: 11510
Work Shop Code: WSC 77878
Additional Info: VSSZZZ1MZ2R089501 SEZ7Z0A1399755
3 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-00 - -
16688 - Cylinder 4 Misfire Detected
P0304 - 35-00 - -
16687 - Cylinder 3 Misfire Detected
P0303 - 35-00 - -
Chassis Type: 1M - Seat Leon
Scan: 01,02,03,08,15,17,19,22,35,46,56
Address 01 -------------------------------------------------------
Controller: 06A 906 032 HN
Component: 1.8L R4/5VT 0002
Coding: 11510
Shop #: WSC 77878
No fault code found.
Address 03 -------------------------------------------------------
Controller: 1C0 907 379 K
Component: ASR FRONT MK60 0103
Coding: 0022017
Shop #: WSC 00001
Address 08 -------------------------------------------------------
Controller: 1M0 820 043 D
Component: 1M-CLIMATRONIC X0605
Coding: 00041
Shop #: WSC 06441
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 1M0 920 902 C
Component: KOMBI+WEGFAHRSP VDO V02
Coding: 05424
Shop #: WSC 00001
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 06441
Address 46 -------------------------------------------------------
Controller: 1C0 959 799 F
Component: 3M Komfortgerát HLO 0003
Coding: 00259
Shop #: WSC 06441
2 Faults Found:
00955 - Key 1
09-10 - Adaptation Limit Surpassed - Intermittent
01135 - Interior Monitoring Sensors
36-00 - Open Circuit
Address 56 -------------------------------------------------------
Controller: 1M0 035 186 F
Component: Radio 0001
Coding: 00403
Shop #: WSC 06441
2 Faults Found:
00852 - Loudspeaker(s): Front
36-10 - Open Circuit - Intermittent
00853 - Loudspeaker(s): Rear
End -------------------------------------------------------
Any ideas anyone?
3 Faults Found:
P0300 - 35-00 - -
P0304 - 35-00 - -
P0303 - 35-00 - -
Coding: 11510
Shop #: WSC 77878
Coding: 0022017
Shop #: WSC 00001
Coding: 00041
Shop #: WSC 06441
Coding: 05424
Shop #: WSC 00001
Coding: 00006
Shop #: WSC 06441
Coding: 00259
Shop #: WSC 06441
2 Faults Found:
00955 - Key 1
Coding: 00403
Shop #: WSC 06441
2 Faults Found:
Any ideas anyone?
