Car fine last night, Took my daughter to work earlier and the engine management light started flashing and lost most of it's power, After 100 yards or so it went out and power picked up but not totally, Still wouldn't pull under load.
Got back and, turned ignition off, Management light still flashing and after about a minute it came on fully, Connected it to the laptop for VAG and I get just the one code, 16884 Random/multiple cylinder misfire detected, Cleared the code and I get the flashing management light obviously because the problem is still there.
Could this just be something simple like a spark plug or plug lead or could it be something else even though I don't get any other codes through VAG.com
BTW, Using VAG 3112 shareware.
Any help appreciated, Off out to do some old fashioned diagnostics
