mil light not working.
TDC
71
is the mil lamp on the top right ? , or one below that ? neither light up at all..:confused:
Is there a lamp check procedure in vagcom ?
longman
Stumped!
Mar 13, 2007
613
Nr Maidstone, Kent
You need to go into instruments, click on 'Output Test' and step through the 'Next' button following the test of each dial.
It will then put each dash light on, one at a time, and V/C will tell you which one should be on.
TDC
71
the tests covered many lamps but not the mil or the one below. .. ?
