MichalR VAG-COM Results
DIFT
Torquing all the Torque
Oct 8, 2004
1,546
Kent/London
5 Faults Found:
17584 - Bank1: O2S (Lambda) Correction Behind Catalyst: Control Limit Reached
P1176 - 000 - -
16786 - EGR System: Excessive Flow
P0402 - 000 - -
17953 - Throttle Valve Controller: Malfunction
P1545 - 000 - -
P1545 - 000 - -
17962 - Throttle Actuator (J338): Conditions for Basic Settings not Met
P1554 - 000 - - - Intermittent
Car fires up to around 1000RPM then dies.
DIFT
Oct 8, 2004
1,546
Kent/London
16786 P0402 Exhaust Gas Recirc.Flow Excessive Detected
17584 P1176 O2 Correction Behind Catalyst,B1 Limit Attained
17953 P1545 Throttle Pos.Contr Malfunction
17962 P1554 Idle Speed Contr.Throttle Pos. Basic Setting Conditions not met
DIFT
Oct 8, 2004
1,546
Kent/London
17953: Throttle body maybe corroded due to water ingress
You can buy them of E-bay fairly cheap I think.
I think your looking at a new throttle body maybe...
Anyone???
DIFT
Oct 8, 2004
1,546
Kent/London
Looking at previous Threads, I would say maybe a throttle body has gone.
Not sure if you can try a TB allignment?
DIFT
Oct 8, 2004
1,546
Kent/London
Check you have code for head unit.
remove negative of battery for few mins, then reconnect, ignition on but engine not running. leave for 3 mins or till highpitched whine from engine has stopped before starting
MichalR
191
Bromley, London
I followed your procedure but nothing happened...so i though i may have connected up a bit too early so i disconnected the cable and left it for around 20mins....came back connected it all up switched the ignition...left it for a few secs then tried to start it...nothing....second time round had my foot flat on the accelerator and it burst back into life...idels like normal and everything :)
BUT the EPC and engine light is still on and i dont want to take it out for a drive incase it decides to die on me again.
I have never been so confused by a car in my life!
Any ideas on what it could be?
DIFT
Oct 8, 2004
1,546
Kent/London
Mystery to me... Obviously when the RAC man tried to disconnect the battery for a bit, he didnt leave it off long enough.
I'd be tempted to drive it up and down the road a few times, to see if anything happens.
I think you have to leave the ignition on for quite a while before the alignment starts.
MichalR
191
Bromley, London
Well i decided to take it out for a few laps of the roads around me...felt ok but a bit down on power...then the EPC light flashed up again...so i chickened out and decided to get it home!
I dont know wether to laugh or cry :confused:
