Max boost on a PD130
TooMuchBoost
How much boost can the stock internals of a healthy PD130 withstand?
For those with aftermarket turbos (like a 17/22) what is a strong but streetable sustained boost setting/value and roughly what BHP value would this be?
While this might be old to you I'm blazing a new path on this side of the pond and appreciate the knowledge.
devonutopia
fabia-lous
Mar 30, 2004
1,200
Exmouth / Exeter
My chipped PD130 with VNT20 hybrid peaks at something silly like 2.2 - 2.3 bar in some gears, but is set to a steady 1.8 bar, whatever that is in LB? 26psi. :) It does hold 2.0 bar constant at times, but usually is a bit lower.
Aug 1, 2005
2,695
Cullompton . Devon
My Cupra was chipped to 2.2 bar which is 32.34 PSI but i did have it running at 2.4 bar - 35.27 PSI for a while.Its not what pressure the engine can safely run at it`s more down to what the turbo can handle.
muddyboots
Still hanging around
Oct 16, 2002
5,739
Welcome :wave:
Both the remaps I've had on PD130s have held boost around 1.55-1.6 bar.
This is on standard engines with standard turbos.
I'm getting a revised Upsolute map today, with reduced torque at lower rpm to prevent clutch slip, and a stronger top end than standard.
I'll hopefully do some logging with vag-com when it's done, and see what's changed.
Aug 1, 2005
2,695
Cullompton . Devon
Neo_VR said:
And allards do a "VT7" turbo... christ knows what boost it runs... but 300bhp and over 400lb/ft when kitted out with injectors, zorst and fmic :-o
There will be a secondhand VT5 for sell in about six months time hopefully funds permitting if your interested. :whistle:
faboka vrs
63
Liverpool
Does anyone know what the VT range are based on. Take it the low number are based on the GT1749VA(b) will a GT20 Compressor. Do they use the GT2052/GT2056 for any of them?
Triple D
Mike, i would say yes to your turbo, but after my last experiance, i think i will buy a new one with lovely warranty :) and get the injectors at the same time :)
See who the daddy is then :p
DIFT
Torquing all the Torque
Oct 8, 2004
1,546
Kent/London
MMMMMM, :think:
I may get saving up now :)
Aug 1, 2005
2,695
Cullompton . Devon
There`s a 2.1 stroker kit avaiable for the 1.9 PD TDI engine now mate. I would love to have that fitted to my Cupra.
You know i feel really sorry for you about my old turbo blowing up but you also broke the new replacement turbo.
