Pabs
5,936
Basingstoke
Hi All,
I wish I knew more about cars. But I need some techie explanation if possible.
My mate's mk4 ibiza has a problem. Clutch is slipping and smelling, and the clutch pedal feels all wrong. (A bit like putting foot in treacle?!?!)
Also, car is leaking a fluid onto the floor/road where it is parked. Fluid looks brown/black he thinks. Car is otherwise running normally, no warning lights etc.
Can anyone explain what this might be? Diagrams or links would be fantastic.
My assumptions, which are probably all wrong:
The clutch uses slave/master cylinders - no idea what these really do, but assume they assist in releasing/engaging the clutch - hydrolic fluid??? Is it this fluid that is leaking, perhaps from a seal or bearing, that is getting into clutch and causing the slip?
Sorry, I'm a real thicko on this in-depth technical stuff. :(
OK, Master cylinder attached to the pedal. Slave cylinder attached to the transmission and throw-out bearing....
Fluid passes from Master to Slave as/when pistons move about... This fluid then goes back and forth, depending on pedal position.....???
normally fluid goes from MC, thru pipes into SC - close system
if it's leaking..... then the clutch might not be fully making contact (hence the smell) - and will only get worse as the fluid drops
assuming it's that
then again, no dropping fluid is good
ok... makes sense i think.
So this fluid must be the hydrolic fluid then. Am I right in thinking the cylinder would be bolted to the firewall area? Where can you check the level?
it should pull the fluid from the brake fluid reservoir (I think) - so definately worth checking.....
you're right though, it's on the firewall, near the brake servo
ah okey dokey... not as thick as i thought then! :)
If it uses brake fluid, surely this leaking would decrease effectiveness of brakes themselves?
ah ok. Apparently there is a good few puddles under the car.... but the leaking seems to have slowed (which would be because the car isn't being driven, and hence fluid isn't being forced out...... i'd think.)
Where would the fluid most likely leak from? The SC, or MC?
And if caught early on (ish) I'm assuming the clutch/flywheel etc should still be ok and useable?
yeah, if the clutch isn't burnt out it'll be OK.
to be honest, it could be either that needs replacing - best bet is to pump the pedal while someone looks for leaks
