MASSIVE jolt when lifting off in 1st/2nd... HELP!
RaggedLob
The worst is yet to come
Mar 29, 2009
179
Thatcham, Berkshire
I drive a 3cyl 1.2 12v, which, ever since i bought it, has had a real problem with smoothness in the lower gears...
Lifting off the throttle (even lightly) in 1st or second gear causes a HUGE painful jolt to resonate through the cabin, and the whole car jerks back. this is regardless of revs, it can happen anywhere between 1500RPM up to the redline. My independent mechanic told me it was a characteristic of 3 cylinder engines, which seems odd...:confused:
My Dad told me it could possibly be a rubber stop in the engine bay which holds the revs in low gears, and it's worn through/ shot... any ideas?
Cheers, Lawrence
RaggedLob
Mar 29, 2009
179
Thatcham, Berkshire
Revving the Engine seems fine, bit noisy and shaky, especially when cold, but that's to be expected with a 3 cylinder..
i'm reluctant to take it to the Stealers, purely cos i'm a student and can't afford the labour, but ill try and find a cheap independent to have a look :)
Anyone else have this problem?
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
When the engine is cold, grapple the engine & rock it back & forth, side to side - does it move (much?)
seremotors
Dave the Parts Manager
Mar 11, 2008
12,507
9
Belfast UK
www.seatcupra.net
Worth checking for a broken front coilspring as well.
Is there any loss in power lately? A failed ignition coil (1 per cylinder) can make it very jumpy and rough.
I jump into our 1.2 Ibiza loan cars occasionally and I do find that they seem very 'sharp' and the revs sometimes seem to have a mind of their own . . . . .
RaggedLob
Mar 29, 2009
179
Thatcham, Berkshire
Just tried this, it moves slightly on the suspended balancer mounts on top, but i'm sure that's normal..
I've driven demo Ibiza's and Polo's with the same engine, none had this :confused:
Think it may be what Disco Biscuit said, a Gearbox mount of some sort, might take it to Newbury Seat to see if a mechanic could identify it
cheers for the replies guys :)
Nath.
The Gentlemans Express
Jan 1, 2006
8,620
16
EASTLEIGH, HAMPSHIRE
I had a problem on a mk3 1.6 sport that sounds almost the same, you could not hold the revs at 2k. in neutral if you touched the gas even a tiny bit it would jump from tickover to just over 2k. If you set the revs at say 4k and slowly come down, you could go 4k, 3.5k,3k,2.5,2k bang tickover. The potentiometer in the throttle pedal was faulty and a new one fixed it.
In neutral can you go up and down the revs slow and smooth in 500rpm stages without any jumps or skips?
Acksaw
Confused
Apr 25, 2009
289
Newcastle, Staffs
www.acksaw.com
Mine does this but I just assumed it was me not letting the clutch out smooth enough or letting it out to slow and then it jolting as the revs being higher than they should be when letting the clutch out fully
