Map sensor replacement pipe
brad1
Evening all
Im going to get a map sensor replacement pipe from forge, the one people use on their lcr custom fmic set ups, such as nev etc, just wondering, will a map sensor from a tdi fit in this, are the map sensors from a tdi the same shape and fitment as the ones on a lcr and lc?? :)
brad1
i used my old one that comes with car an so far no problems
Mine isnt a LCR, im not after the plastic pipe, i just need to know if the tdi map sensor will fit in the map replacement tube for the lcr??
brad1
Right, make it a bit clearer :p
Will the map sensor from a tdi fit into this replacement map sensor pipe forge have designed, are the map sensors from a tdi same shape and size as the ones on a lcr etc
brad1
Forge have confirmed it comes with adaptors to fit a diesel map sensor so this will be ordered today :) thanks guys
scottym
Diesel Powered
Sep 19, 2007
124
Ashford, KENT
Does anyone here know if there are two types of MAP sensor fitted to the PD150s? I seem to have one that is very small, and wont fit into my MAP replacement pipee.
Does anyone have some spare reducers?
Scott
