Manual boost?!
ex2reme
te (manual) boost controller works with CUPRA 2008??.. or it has to be electric??...
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
it can be manual.. BUT, if boost control deviates beyond what the ecu is expecting it will drop into limp (actuator pressure) mode. If higher boost is run without checking or other adjustments to fueling and ignition timing, you risk engine damage
ecu control is electronic via N75 valve
ex2reme
thats what happend with me.. (Limp mode) but im trying to find the problem..is the boost controller not compatible or its other problem..
ex2reme
i have boost guage n my car and i have noticed something..the car turbo goes in limp mode when the boost guage reaches beyond 15 psi ..so it means the boost can work with 15 psi without goin to limp mode??!!..because i have removed the boost controller from my car coz its not workin properly..so that it will go back like before with the stock turbo..
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
you cannot overrule the ecu's control over the engine.
get it remapped properly is my advise. dont **** around with bleed valves.
you risk your engine.
ex2reme
i already fixed the blow valve but its not helping with anything
