Main Difference ?
ste27
Hi
Im after a Leon Cupra but not sure which to buy. The Cupra or the Cupra R ?
Is it the same car but with more BHP i.e. Different ECU map or something ? if so, could i buy the cupra and chip it to obtain the R performance or are the differences a little more complicated !!!
Thanks in advance
Ste
kenboon
389
Derby
Hi
Thanks in advance
Ste
The R has a larger turbo than the cupra , uprated suspension and better brakes. You should see R performance from a Cupra after a remap around the 210 Ish Bhp mark.
The R also has a slightly different body style too.
Its been covered alot m8 prolly best to do a search for more info.
Ken
1835harri
The legend
May 21, 2007
361
Llanelli, SW Wales
if you are going to get a cupra and chip it to be the same as the cupra then you may as well get a cupra R.
I always wanted a cupra r and nothing but, but stumbled across a ovni yellow turbo cupra and have not looked back since.
Cupraloon
I have the 20vt cupra, and now wish i'd spent the extra buying the "R" tbh, you have to consider what it going to cost firstly the R will cost more to buy, more to insure depending on your age, you'll probably want to start adding/ changing bit's like wheels suspension, arb's etc, etc, which you'll want to do to either especially the cupra 20vt cos the handling isn't up to much if you push it too hard, better to start with the "R" first i personally feel, at least now i do..... :doh:
Although it's a bit late for me cos i've started the mods already, if i was in your position i'd way it all up and go for the "R" ....
ste27
Dont suppose any1 is selling one ! i live in the Lancashire area.
BCM
Keyboard Gangster
Feb 1, 2005
2,680
Wishaw, North Lanarkshire
Look and travel, thats what i did, traveled from Glasgow to Heathrow for mine!
Get the R! You will not regret it!
Oh and your lucky no one like DPJ, RobM or Me was on at 11 last night to reply to this post with a HUGE search picture!
