maf sensor prices
lanceneoman
The Turbo Power
Aug 24, 2008
144
west mids
ive recently had my car checked for faults and it had a maf sensor fault and a dumpvavle fault so ive had a baileys dumpvalve( recirc) fitted and now its just the maf sensor any ideas how much?
andycupra
status subject to change
how difficult is it to put a LCR maf on a LC?? and will it make a diffrence or are they the same???
Dont. you need the maf thats matched to your ecu and pipework, so it wont work.
Even on 'like for like' leon cupras there are several versions of mafs, which if incorrect wont work correctly.
But if you want to know..
the LCR maf has a larger diameter housing, so it wont fit for starters without changing all the inlet pipework, and even then the figures the ecu would recived would be incorrect and require the ecu to be adjusted. all for no benefit unless you spent 1000s more on a larger turbo and pipework. Which would be easier to do by just getting a LCR.
mikey_b
322
Manchester
well ive just got a fmic and injectors 640cc all i need is a big turbo pref gt2871r,maf and a manifold...
