So I have been investigating lowering options for my 04 Ibiza TDI 130 and need some advice..
I want to lower between 30-35mm as I want to take a bit of the height off the car, but still be able to get over speed bumps, potholes and through puddles without difficulty.
After visiting a local modification shop and discussing options with the staff, I have the following options..
A. Lowering springs with the standard shocks (£180)
B. Lowering springs with new shocks (£400)
C. Coilovers (£500+)
For what I want to achieve I was advised to go with option A, which would lower the car a bit, but not improve the handling as much as B or C .. I was concerned with using 30mm lower springs on the standard shocks, but I was told that for 30mm the standard ones would be fine.. and is only if I wanted lower they would recommend B or C.
So..
Would 30mm springs be ok with the standard shocks (MOT wise and durability wise)? I know some people here have dome something similar.. is it ok?
Finally does a 30mm drop still allow you to get over speed bumps ok and not have tyres rubbing the arches etc?
thanks.
So..
thanks.
I'm running on Eibach springs (35mm front, 25mm back) which have realistically lowered it my 25mm front and about 10mm back (because the FR standard suspension is lower than a "normal"
, how many miles have you done on them? And get throught the MOT no prob I presume?
