been advised mine needs changing on passengers side, is it hard to do your self ? also how much should I be looking to pay for the part ? I was goin to ask on seres but dnt know the part number
does it rattle over bumps with a knackered ball joint as mines rattling its a*** off & ive changed all the bushes & this is my next thought of what it might be.
the knocking you could hear over most bumps, after replacing the ball joint the knocking stopped was just kinda a big clunk as soon as you hit the bump
Sounds exactly like mine , my ball joint is split and leaking grease and clunks when you hit a bump, Did you remove then hub then remove the ball joint or did you just disconnect the drive shaft and wishbone from the ball joint ?
didn't even need to disconnect the drive shaft, just 3 bolts holding it on the the wishbone undo these and move the wishbone down and then removed the last bolt connecting it to the car, just make you you have some penetration fluid quite an easy job now I know what I'm doin
