lots of Soot but no faults
cordoba lad
Back in the Midlands
May 24, 2005
180
Warwick
Right started the car up this morning and the cloud of soot that blow out the exhaust was something to behold.
So this evening I've plugged the car into VAG Com and done a little bit of logging. The Actual vs request MAF figures are up and down sometimes the actual far exceeds the requested and vice versa, similar with the boost figures. Seen as the engine is stock with the only addition being a Green filter I would expect to see the MAF reading being higher consistently across the range but that's not true. The boost pressure is again a little up and down I would expect to lose a bit through the OE joints but doesn't explain why it exceeds the requested boost.
Also logging the torque it gives a figure of 350Nm Peak torque @ 2037rpm does this seem right for a std motor? how accurate is this figure?
May also be worth saying that it is always run on Shell diesel and the car seems to have good and bad days (atmospherics) but they are quite pronounced the difference. The waste gate sound is also becoming more pronounced (sounds like a small cough).
So the long and short is that the car runs fine there seems to be more soot recently. Any Ideas as I'm a little stumped :confused:??
cordoba lad
May 24, 2005
180
Warwick
Air Filter is pretty clean as I did that not long ago. I'll redo the logs with a couple of different groups as suggested by James.
Then its a case of going crawling under it to look at the pipes.
I'll let you know how I go.
validwarlord
HI James
Did you go for the Custom Rear Brace from Hughes?
validwarlord
Oh James while I think about it reading a few more Threads to do with the EGR (VAG-COM) turning down I have read that you can set it to a new value but soon as you turn off the car and restart it goes back to the orginal setting is this anything you have heard of?
Car information Seat Leon FR Tdi 04 plate.
james walker
cooling is the key people
May 24, 2007
5,121
retford notts
never heard of this mate, wouldnt have thought it would reset.
try posting a q in the tdi section, sure loads have done it mate.
