lot's a questions!
fuddbutter
ok first what model cordoba do i have??
How much truble am i going to have fitting 17in rim's on it?
has anyone had problems wih rubbing at all?
i want to take the dash pod out to spray the plastic pice around the tacho and other gages, any hints on how to do it?
hmmm... there is something else ill have to go think about it hehe :jog:
Look most like a Cordoba SXE...
17's should go straight on....the only rubbing you might have is on the arch liner which is easily trimmed.
Removing the clocks/pod should be very easy.....unscrew the 2 screws at the top of the plastic surround, the plastic surround then pulls out. Once the surround is removed there are 2 screws holding the clocks in, remove the screws from either side.....the clocks should then pull foward.
Hope this helps.
BradsSEAT
Heya fuddbutter,
Great to see another Aussie on this site.
Same model as mine...its a 1996/97 Cordoba GLX 1.8Ltr 8v.
fuddbutter
hey brad, good to see some other cordie owners in aust!!
love the pic's of ya car!!
hopefull this weekend ill take some more pic's of mine mine to show it of to the world!
