right as you may have read my other threads im still stuck and getting really annoyed with it now.
other day i was driving about giving it some and after that i had hardly any boost, looked under the bonnet and the n112 thingy bob had the connection melted of it from were i had done my n249 by pass as the n112 thing was flapping about so must of fell behind and melted on something. fair enough. bought some resistors 330 ohms and 5w fitted them on to the two thingy bobs i needed to (pics below) that i read from searching on here (pics below) and also had a direct silicon hose from under the throttle bodie to the top of my dump valve (also pics below)
vag com it and cleared it all (it said about MAF voltage to low and something about lambda) the TCS light is still on? BUT the engine light did go and stay out.
so i went for a drive, and hey ho hardly any boost again. i can hear it spool up and that and dumps. but it goes no were, it smokes a bit too and pops (only white smoke) so hopefully one of you lot can help as im stuck i got the vag com results below as well as under bonnet shots:
oh and i have bought 330hms and 10w resistors of a member on here which will come tomorrow but a local electronics shop said these would work find.
vag com:
VAG-COM Version: Release 409.1-US
Control Module Part Number: 6K0 906 032 AA
Component and/or Version: 1.8L 20VT EU3 0002
Software Coding: 10500
Work Shop Code: WSC 79154
11 Faults Found:
17833 - EVAP Purge Valve (N80): Short to Ground
P1425 - 35-00 - -
17955 - Shareware Version. To Decode all DTCs
P1547 - 35-00 - Please Register/Activate
17525 - Shareware Version. To Decode all DTCs
P1117 - 35-00 - Please Register/Activate
17843 - Secondary Air Pump Relay (J299): Short to Ground
P1435 - 35-00 - -
17829 - Shareware Version. To Decode all DTCs
P1421 - 35-00 - Please Register/Activate
17697 - Shareware Version. To Decode all DTCs
P1289 - 35-00 - Please Register/Activate
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-00 - -
17523 - Shareware Version. To Decode all DTCs
P1115 - 35-00 - Please Register/Activate
17522 - Shareware Version. To Decode all DTCs
P1114 - 35-00 - Please Register/Activate
16518 - Oxygen (Lambda) Sensor B1 S1: No Activity
P0134 - 35-00 - -
16524 - Shareware Version. To Decode all DTCs
P0140 - 35-00 - Please Register/Activate
pics:
someone PLEASE help me lol sorry for any spelling mistakes or anything im freezing and in a rush
vag com:
11 Faults Found:
P1425 - 35-00 - -
P1435 - 35-00 - -
P0102 - 35-00 - -
P0134 - 35-00 - -
pics:
