loss of power
andymac
after say about an hour of driving i sometimes get a loss of power !
i have an LCR with a cc stage 1 remap done by jbs .
if then i turn it off and leave for about 10 mins its back to normal ! could this be down to heat soak ?
when it has a loss of power its like its running the standard 222bhp .
anyone else had this ? wouldn't of thought heat soak would of been a massive prob in this weather !
cheers andy:)
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
Hows your air induction system?
What do you have?
Car serviced regularly?
Have you had someone with VAG com check your car for fault codes?
What DV do you have?
Seems strange but heat soak has never bothered me, but it could be
traumapat
Leon Cupra IHI
Jul 24, 2005
5,925
sunny sussex
drive gently for an hour and see if it happens. also will gentle driving after the decrease eventually restore the power?
do you have a boost gauge?
sounds like its going into soft limp if its fine after restart.
andymac
What do you have?
car just been serviced .
i had the forge 007p when i bought it ! but thats ok (took it off and checked it over )
i have a k&n panel filter . the maf is new .
andymac
Could be Limp mode
thought limp mode reduced it to manifold pressure to reduce all damage ? this still has boost all be it reduced a little :shrug:
its only done it a few times ! if it carries on i will shoot back to jbs and get them to check the map
