Hi
Having a bit of a problem with my 1.4 at the minute, it seems to be going through oil very quickly. I filled it up about 6 weeks ago with 2.5 litres and when i checked it today it was below the minimum marker.
I've had a look in the garage and i cant see any oil marks on the floor, so im thinking it may be either leaking out whilst the engine is running, or being burnt somewhere. Is there any way i can check this?
I've checked around and i cant see any oil leaks in the engine bay, but the engine has the plastic cover on it so i will have to wait till the weekend and take that off and have a look under there.
I've also checked the dipstick and under the oil cap and i cant see any of the mayonaise type gunk round there so hopefully it isnt the head gasket.
The only other problem im having is that the car seems to be using a lot of pertrol (about 260 miles per full tank of normal unleaded), but i assumed that this was the lambda sensor. Could these problems be related???
Thanks in advance,
Dan
Thanks in advance,
Dan
