Looking for dataset 5WA907556E - 6C: Back-up Cam. (J928) for Cupra Formentor
Pepcox
32
8
Slovakia
Hi,
I'm looking for dataset parametrization file for 6C: Back-up Cam. (J928):
Module: 5WA 907 556 E
Car: Cupra Formentor 2022
It is control unit for AreaView 360 which was additionally installed to the vehicle. Unfortunately the unit comes without dataset file uploaded (or with the wrong one) so I need to upload new one. The problem is that I cant find it anywhere and no one is willing to provide some.
Is here someone who have access to those dataset file and would be kind enough to provide it I would appreciate that?
Thanks in advance!
Here is a log:
Code:
Address 6C: Back-up Cam. (J928)       Labels:* None
   Part No SW: 5WA 907 556 E    HW: 5WA 907 556 D
   Component: TV eEntry     H29 0244
   Serial number: FZ6ESP140722000
   Coding: 04033300843000
   ASAM Dataset: EV_CamSysTVFicosMQB37W 006011
   ROD: EV_CamSysTVFicosMQB37W.rod
   VCID: 52FC7AF054693EEAE9F-8006
   Subsystem 1 - Part No SW: *ªªªªªªªªªª    HW: *ªªªªªªªªªª
   Component: ªªªªªªªªªªªªª  ªªª ªªªª
   Serial number: ªªªªªªªªªªªªªªªªªªªª
3 Faults Found:
10487040 - invalid data record
          B2005 00 [047] - -
          [ECU (DatasetDownload)_DataSet not valid]
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 4
                    Fault Frequency: 2
                    Mileage: 20220 km
                    Date: 2023.05.23
                    Time: 12:34:45
Miket
25
15
In most cases the chinese controllers don’t come parameterised, you may find you have the same problem, as good as useless units
It's extremely uncommon to get any new control unit that comes parameterised, regardless of origin
Even when they're parameterised when buying used, it's good practise to replace the datasets due to the sheer number of variables. It's not as simple as one dataset for one model
We have the factory ZDC on order for E, we only currently have D which is what we fitted to the last Formentor we installed area view on
