Logs after new temp sensor fitted
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
Replaced the temp sensor and done some logs to see any different.
Am i running rich or lean? :confused:
Code:
Monday	24	December	2007	17:45:36
06A 906 032 T  		1.8L R4/5VT         0003
	Group A:	'003				Group B:	'020
		Idle speed	Air mass in	Throt Angle	Ignit Angle		Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization
	TIME	700-820 rpm	2.0-4.5 g/s	0.2-4.0%	0-12 BTDC	TIME
MARKER	STAMP	 /min	 g/s	%	°	STAMP	 CF	 CF	 CF	 CF
	0	1720	20.14	13.7	12	0.36	0	3.8	0	0
	0.76	1920	33.53	26.3	17.3	1.16	0	2.3	0	0
	1.56	2160	45	100	8.3	1.96	0	1.5	0	0
	2.36	2520	63.97	100	10.5	2.74	0	0.8	0	0
	3.14	2960	91.75	100	9	3.54	0	0	0	0
	3.94	3440	132.33	100	7.5	4.34	3	0	3	3
	4.74	4000	144.56	100	9.8	5.14	3	0	3	3
	5.54	4440	153.03	100	10.5	5.94	3	0	3	3
	6.34	4880	158.06	100	12.8	6.76	2.3	0	3	2.3
	7.16	5280	160.97	100	10.5	7.56	2.3	0	2.3	2.3
	8.06	5600	164.31	100	12	8.45	2.3	0	2.3	2.3
	8.86	5920	166.06	100	15.8	9.25	1.5	0	1.5	1.5
	9.66	6160	165.08	100	19.5	10.05	1.5	0	1.5	1.5
	10.46	6400	166.53	100	18.8	10.85	1.5	0	1.5	1.5
Code:
	Group A:	'115				Group B:	'031
		Engine Speed	Engine Load	Spec. Boost	Actual Boost		Voltage	Voltage
	TIME	700-6800 RPM	15-150%	990-1800 mbar	<=1800 mbar	TIME
MARKER	STAMP	 /min	%	 mbar	 mbar	STAMP	 V	 V
	0.43	1720	30.1	990	1010	0	0	0.115
	1.32	1840	81.2	2310	1140	0.83	0.7	0.66
	2.12	2080	100.8	2320	1360	1.72	0.59	0.235
	3.03	2440	122.6	2300	1650	2.63	0.185	0.645
	3.83	2800	142.9	2280	1890	3.43	0.135	0.61
	4.62	3240	181.2	2210	2300	4.23	0.635	0.7
	5.42	3720	191.7	2140	2420	5.03	0.825	0.785
	6.22	4200	186.5	2120	2320	5.82	0.865	0.76
	7.03	4640	178.2	2090	2170	6.62	0.87	0.745
	7.93	5040	168.4	2050	2020	7.53	0.89	0.765
	8.84	5440	159.4	1940	1910	8.43	0.89	0.775
	9.74	5800	150.4	1840	1820	9.34	0.89	0.77
	10.54	6080	142.1	1770	1760	10.14	0.885	0.765
	11.43	6360	137.6	1700	1740	11.03	0.885	0.775
	12.33	6600	133.8	1670	1710	11.93	0.89	0.775
	13.13	6640	49.6	990	1790	12.73	0.89	0.775
Code:
	Group A:	'118				Group B:	'032
		Engine Speed	Air Temp In	Boost Dut Cyc	Actual Boost		Idle O2 Adapt	Run O2 Adapt
	TIME	700-6800 RPM	<=110 C	0-100% 	<=1800 mbar	TIME	-10.1	-10.1
MARKER	STAMP	 /min	°C	%	 mbar	STAMP	%	%
	0	1560	44	0	1020	0.4	0.9	0.8
	0.8	1640	44	100	1030	1.2	0.9	0.8
	1.6	1840	42	100	1190	2	0.9	0.8
	2.4	2120	42	100	1400	2.8	0.9	0.8
	3.2	2440	41	100	1650	3.6	0.9	0.8
	4.11	2880	41	100	1940	4.61	0.9	0.8
	5.01	3360	42	96.5	2370	5.41	0.9	0.8
	5.81	3880	43	89.8	2400	6.21	0.9	0.8
	6.61	4320	45	89	2280	7.01	0.9	0.8
	7.41	4720	46	90.2	2140	7.81	0.9	0.8
	8.3	5120	49	93.7	2010	8.82	0.9	0.8
	9.22	5480	51	97.3	1910	9.71	0.9	0.8
	10.11	5800	54	89.4	1840	10.51	0.9	0.8
	10.91	6040	56	86.7	1780	11.31	0.9	0.8
	11.71	6280	58	80.4	1760	12.11	0.9	0.8
	12.51	6480	60	83.5	1740	13.01	0.9	0.8
