Locked out of car
CatB1
535
Manchester
www.freeserve.com
As above.Delocked the drivers door back in May of my Mk3 Cupra,at the same time put new battery in the key fob.Came to unlock the car tonight with the fob & the car stays locked,the fob LED flashes as normal when pressed.Access through the hatch is possible but how do I deactivate the alarm & immobiliser?
Pete
Nov 27, 2006
1,204
www.cardomain.com
Think you're just gonna have to be quick ... and a little brave
Access through the boot is with the key yeah ? Only my Toledo locked me out a few weeks ago and the central locking opened the boot but non of the doors.
When I finally got in (don't ask) I stuck the keys in the ignition, turned to the first click and opened the door from the inside.
I don't know if sticking the key in the ignition will turn off the alarm on it's own, but it may re-sync something
.... either that, or you'll have very angry neighbours :(
pickie
222
had the bat changed in my key fob the other week, and it still works like a charm ???
you didnt leave the bat out for more than 20 secs ?? as i think that may then wipe the key ?? but not sure, got mine done at a watch shop so he took like 5 secs to change it
GTi T
410
North West
Sounds like he changed the battery in the key fob in May this year so it must have worked since guys......
CatB1
535
Manchester
www.freeserve.com
Sorted.Climbed in thro' boot with the alarm going off.Disconnected battery & changed door lock back to one with key.Reconnected battery & turned alarm off using key in door handle.Carried out resync of key fob & it's back to normal being able to lock/unlock with fob.Why it stopped working I don't know,but its back to normal.Will put the delocked handle back on tomorrow and hope it does'nt happen again.
Pete
