Loads of issues - Help required
Jamie_B
DERV
Oct 14, 2004
38
Ayrshire
Seat Ibiza 2012 1.6 tdi FR
Code:
Chassis Type: 6J-SE25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 44 4B 56
VIN: VSSZZZ6JZDR082683   Mileage: 86310km-53630miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Cannot be reached 1100
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
4B-Multifunc. Module -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
Address 01: Engine (J623-CAYC)       Labels:. 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 LE    HW: 03L 906 023 Q
   Component: R4 1.6l TDI   H33 9978
   Revision: --H33---    Serial number:
   Coding: 00114016002500080000
   Shop #: WSC 131071 1023 2097151
   ASAM Dataset: EV_ECM16TDI02103L906023LE 003011
   ROD: EV_ECM16TDI02103L906023LL.rod
   VCID: 74B1DFB4AE3D03A78AD-8020
2 Faults Found:
7332 - Mass Air Flow Sensor (G70)
          P0103 00 [032] - Signal too High
          Intermittent - Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Date: 2000.00.00
                    Time: 00:00:00
                    Engine speed: 0.00 /min
                    Normed load value: 0.0 %
                    Vehicle speed: 255 km/h
                    Coolant temperature: 10 °C
                    Intake air temperature: 11 °C
                    Ambient air pressure: 1000 mbar
                    Voltage terminal 30: 11.294 V
                    Unlearning counter according OBD: 40
                    Engine speed: 0 /min
                    Battery voltage: 11.3 V
                    EGR Vacuum Regulator Solen.val.: activation-ANG_SP_EGRV[0]: 0.000 %
                    Throttle_actuator_commanded_value-ANG_SP_THR[0]: 96.001 %
                    Air mass: specified value-MAF_SP_MMV: 239.95 mg/stroke
                    Air mass: actual value (mg/stroke)-MAF_MES: 0 mg/stroke
6086 - No Communication with ABS Brake Control Module
          U0121 00 [173] - -
          MIL ON - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 31
                    Mileage: 86278 km
                    Date: 2018.09.26
                    Time: 10:56:21
                    Coolant temperature: 58 °C
                    Intake air temperature: 16 °C
                    Ambient air pressure: 1010 mbar
                    Voltage terminal 30: 12.311 V
                    Driver request torque-TQI_DRIV_SUB: 0.00 Nm
                    Control Module temperature-TECU: 5 °C
Readiness: 1 1 0 0 0
Address 03: ABS Brakes
Cannot be reached
Address 04: Steering Angle (G085)       Labels:* 6R0-959-654.clb
   Part No SW: 6R0 959 654     HW: 6R0 959 654
   Component: LENKW.SENSOR  H06 0060
   Serial number: 090465LGL0009A
   Coding: 01
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_LWSKLOVW25X 005001
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EA5FD9C907159F7EC9-802A
1 Fault Found:
336900 - Databus
          U1121 00 [009] - Missing Message
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 29
                    Reset counter: 64
                    Mileage: 0 km
                    Date: 2018.09.25
                    Time: 10:38:46
                    Voltage terminal 15: 10.90 V
                    Voltage terminal 30: 11.25 V
                    Terminal 15 status: On
Address 08: Auto HVAC        Labels: 6J0-820-045.clb
   Part No SW: 6J0 820 045 A    HW: 6J0 820 045 A
   Component: J301  Klimaanlage   0330
   Revision: 00 26 08    Serial number: 0000002542340-
   Shop #: WSC 06402 785 00200
   VCID: 2411EFF452DDD327DAD-8070
1 Fault Found:
01316 - ABS Control Module
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 6
                    Fault Frequency: 24
                    Reset counter: 64
                    Mileage: 86270 km
                    Time Indication: 0
                    Date: 2013.02.15
                    Time: 10:38:50
Jamie_B
DERV
Oct 14, 2004
38
Ayrshire
Code:
Address 09: Cent. Elect. (J519)       Labels:. 6R0-937-08x-09.clb
   Part No SW: 6R0 937 087 K    HW: 6R0 937 087
   Component: BCM PQ25 H+4  H46 0254
   Revision: BF046001    Serial number: 0434 195120431
   Coding: 24882BE888612500922008F06E0B0CC8008043EC608C0000200000000000
   Shop #: WSC 64564 324 38760
   VCID: 45D75270B5A7CA2FED3-8010
   Subsystem 1 - Part No SW: 6R0 959 802 M    HW: 6R0 959 802 M  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  002 3110
   Serial number: --------------------
   Coding: 030000
   Subsystem 2 - Part No SW: 6R0 959 801 P    HW: 6R0 959 801 P  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  002 3110
   Coding: 020000
   Subsystem 3 - Part No: 1K8 951 171 A
   Component: DWA-Sensor 00  001 0103
   Coding: 000000
   Subsystem 4 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HO  H05 1501
   Coding: 000000
   Subsystem 5 - Part No: 1K8 951 171 A
   Coding: 000000
No fault code found.
Jamie_B
DERV
Oct 14, 2004
38
Ayrshire
[CODE]
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 6R0 959 655 K HW: 6R0 959 655 K
Component: VW10AirbagA0D H10 0020
Revision: -------- Serial number: 003GX01AXG3T
Coding: 003044
Shop #: WSC 06401 785 00200
ASAM Dataset: EV_AirbaVW10BPAVW250 A01001
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4ACD614C9C392557001-801E
Crash sensor for side airbag: driver side:
Serial number: 3495RRB400G4UHC4B93O
Crash sensor for side airbag: front passenger side:
Serial number: 3505RRB400G4UHC4JOC5
2 Faults Found:
12854016 - Databus
U1122 00 [009] - Implausible Message
[Kombi1 DLC Error]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 19
Reset counter: 64
Mileage: 86315 km
Date: 2018.10.03
Time: 00:05:09
12656896 - Databus
[Bremse8 Time Out Error]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 23
Reset counter: 64
Mileage: 86270 km
Date: 2018.09.25
Time: 10:38:49
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 6J0 920 904 C HW: 6J0 920 904 C
Component: KOMBI H04 0508
Serial number: 00000000000000
Coding: 410A00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
ROD: EV_Kombi_UDS_VDD_RM09_SK46.rod
VCID: 2B0304C833831C5F1B7-807E
1 Fault Found:
12656896 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Steuergerät für Bremse: keine Kommunikation]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 64
Mileage: 86315 km
Date: 2018.10.03
Time: 00:01:13
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 H46 0254
Revision: BF046001
Coding: 022300
VCID: 70B9D3A4DAA53F876E5-8024
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 32
Reset counter: 64
Mileage: 86270 km
Time Indication: 0
Date: 2013.02.15
Time: 10:38:48
[/CODE]
Jamie_B
DERV
Oct 14, 2004
38
Ayrshire
Code:
-------------------------------------------------------------------------------[/COLOR][/COLOR][/COLOR][/LEFT]
[COLOR=rgb(85, 85, 85)][COLOR=#000000][COLOR=#000000]
[LEFT]Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H04 0508
   Serial number:
   Coding: 000000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A8DC1CCFCF9C557201-803E
Address 44: Steering Assist        Labels: 6Q0-423-156.clb
   Part No: 6R0 423 156 B
   Component: LenkhilfeTRW        V277
   Coding: 11221
   Shop #: WSC 06402
   VCID: 2F3B10D80E5B607F37F-807A
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
            79-00 - Please Check Fault Codes
Address 4B: Multifunc. Module        Labels: 6J0-959-441.clb
   Part No: 6J0 959 441
   Component: MF-Modul       0007 0001
   Coding: 0000001
   Shop #: WSC 77005 000 00000
   VCID: 70B9D3A4D6A53F876E5-8024
Jamie_B
DERV
Oct 14, 2004
38
Ayrshire
It wouldn't let me post my full scan in one post so its spread over a few.
No idea why one of them won't work with the CODE script?!?
Anyhow, looking for any ideas on what can be wrong with the car.
Legojon
I only wanted a remap
5,309
2,739
I'm tempted to say what seems obvious. MAF Sensor, Steering angle sensor, etc. However, I find it hard to believe that many sensors have failed at the same time. Wondering if it's more like an electrical short or fuse that's causing multiple errors.
Jamie_B
DERV
Oct 14, 2004
38
Ayrshire
Yes I didn't think all those would fail at the exact same time.
Car had been fine until one day last week the dash lit up like Blackpool. I should also have stated that the speedo doesn't work either now. Well the revs are fine but no speed is noted by the needle.
Legojon
5,309
2,739
Also... what condition is your battery in?
Jamie_B
DERV
Oct 14, 2004
38
Ayrshire
I'll check out those fuses directly.
I think the battery is probably original (62 plate) so you think that might contribute to the issues?
Legojon
5,309
2,739
I'd at least check the battery voltage to get an idea of what state it's currently in. Check the simplest / cheapest options first. But a failing battery can cause all kinds of lights / false readings.
