Razoo
The later Leon 2.0TSI FR has a LSD (Limited Slip Differential). It seems this is an electronic LSD that works in conjunction with the ABS. I haven't found a comprehensive description of how the LSD works, but I assume it applies the brake to the wheel that has lost grip, thereby transferring the power to the other wheel. If this is correct, where does the LSD get the hydraulic pressure from to apply the brake? Is there a pressurised reservoir of brake fluid somewhere, and if so, how is it pressurised? Electric high-pressure pump?
Does anyone know how the Leon FR electronic LSD system works?
Does anyone know how effective the electronic LSD is? Is it worth having?
Thanks,
Razoo
Thanks,
Razoo
