I revive this thread since I'm interested myself in the issue
The car is going to have the 60,000 kms (~37,000 miles) inspection at a stealership in about one month. Since it has made 4 years in March, the cam belt and water pump are to be inspected as well for signs of damage or wear - if they are in perfect condition I will change them around the 100,000 km mark.
As there will be some fumbling around the main crankshaft pulley, it's an opportunity to replace it with something better if available.
Crankshaft pulley is iron, weighs about 1.6kg (~3.5lbs) and according to people around the net it does incorporate a rubber harmonic damper.
This is how it looks (a Golf Mk4 version but still a 1.8T):
I for one fail to see the rubber ring which would do the harmonic balancer job...
This is a damaged one from a longitudinal 1.8T (an A4) and the rubber ring can be seen:
Aftermarket options:
Lightweight (not underdrive!) aluminium pulleys from ECS, Craven or other manufacturer. They do not incorporate a rubber harmonic balancer and weigh around 0.3-0.4 kg (0.66-0.88 lbs)
Fluidampr viscous-damping pulley from Fluidampr. This is how it works:
http://www.fluidampr.com/HOWITWORKS.htm
The 1.8T version weighs 6 lbs or 2.7 kg
From
reviews we find out also that Fluidampr dampens the vibrations and helps the smoothness when revving up under open throttle almost to Rolls-Royce levels, or at least this is how it performed on large V6s and V8s.
On the other side, for torquey engines like a chipped 1.8T there is said lightweight pulleys are not suitable, the crankshaft twist would quickly wear out the bearings and previous to that engine smooth running would suffer. Tests made by members of this forum had proven there is no horsepower gain at all.
However, Fluidampr is
heavy, 70% heavier than stock pulley. The basic idea behind lightweight pulleys was to free horsepower wasted by parasitic drag.
Will a Fluidampr decrease available crank hp and by how much?
Or crank hp would not be affected enough to feel the difference?
I'm talking first and fore most to people who had tried at least one of them or they are skilled in engineering or both. Balancing a high-revving engine is a very delicate job subject to great risks.
Thank you
Regards,
~Nautilus
PS this message has been edited after digging some info on lightweight pulleys
