Light Throttle Hesitation Theory - *Technical Input Please*
longman
Stumped!
Mar 13, 2007
613
Nr Maidstone, Kent
Hi all.
Since buying my LC in March, it has always had a hesitation in power when at light trottle. Hot or cold, what ever gear but more noticable at low revs and always when there is little or no boost.
I have searched on here and a lot of people seem to have had the same issue. Reccomendations have been N75, MAF and DV... The usuals but none of these have cured my problem.
Just wondered if anyone can shed some light on my theory that:
When there is no boost from the turbo, the engine is sucking the air in and causing a vacuum. Could this lift the piston in the DV - acting against the spring? If the spring is not strong enough, it could allow any pending boost pressure to dump out of the DV and back through the system again, causing a drop in air flow and a hesitation in power.
As soon as the turbo is boosting properly and is spooled up (from more throttle) there is no vacuum present at all and the problem will not occur.
A fix for this, simply using a more forceful spring I would guess, from what searches etc say..?
My LC is standard with the Yellow spring, therefore, this was not something I had considered. However, I would like some feedback from the more technical and knowledgable just to see if my theory is anywhere near feasible!!
So.... Hit me!! Am i speaking :censored:??
longman
Stumped!
Mar 13, 2007
613
Nr Maidstone, Kent
I hope thats not all that cures it, as I am sure this wouldn't have come out of the factory like it. I might try a stronger spring in my DV to test my theory out....
Its common thing by the sound.
beezasport
Sold the car to buy a....
I've just pulled my split-r out of the tip and bunged the tip so its venting to atmosphere and the problem seems to have gone away. i've got a propper atmos DV on its way to me so im going to try this and see how it goes from there if that runs ok i'm not sure what would be causing the problem. I know its not good to run on full atmos as it can cause problems.
longman
Stumped!
Mar 13, 2007
613
Nr Maidstone, Kent
Yeah, you'll get a light on the dash if there is no charge air going back past the MAF from what I gather.
traumapat
Leon Cupra IHI
Jul 24, 2005
5,925
sunny sussex
have you vagcommed it? i bet you have but dont overlook any fault codes even if they dont seem connected. temp sensor?
have you tried a tb reset?
i had issues when cold... but more jerky than hesitant. fixed eventually by dielectric grease on the maf connection. i think moisture was getting in there and arching.
i still get the odd hesitation/ power loss on steady throttle at approx 3k revs. is it that your experiencing?
longman
Stumped!
Mar 13, 2007
613
Nr Maidstone, Kent
Yeah, thats it, perfect at full throttle but the power occasionaly dies when you hold the throttle still at 2-3K revs - only occasionaly... VAG-COM says nowt and have tried MAF changes and have done the same with the Dielectric grease on the connecitons.
Its not a big issue, just an irritating characteristic that I would like to bottom out!
TB and ECU reset.... Done and didn't really help although the experience was a little smoother!!!! - Hesitation still damn well there!!
traumapat
Leon Cupra IHI
Jul 24, 2005
5,925
sunny sussex
yep mines the same and to add to the list... 2 remaps, different ecu, maf, temp sensor, dv`s ect and nothing has made a difference. i drove myself nuts trying to work it out.... gave up.
the only answer is to drive at full trottle everywhere;) frightening in the multistories though:lol:
it feels like the engine has suddenly reached the requested power , youve not asked for anymore so it suddenly pulls back?
i now treat it as a quirk. although your dv idea has got me going again
longman
Stumped!
Mar 13, 2007
613
Nr Maidstone, Kent
Had a slow day at work so started thinking and drawing doodles etc.....tried to work out what could be causing it.... You never bloody know... :shrug:
I have posted this on the Forge forum too so I would be interested in the experts input!!
I am probably talking nuts but its got to be something...
Laughed at the full thottle gag.... Might raise a few eyebrows in my Ville too!! :banned:
The most irritating quirk these cars have.... Still love mine though!! ;)
Avant4me
359
Bristol
This sound more like something related to the throttle position sensor, is there any adjustment availalble in it?
chriswilks
Astra CDTi track car
Jun 3, 2007
330
warrington cheshire
this sound similar to what my car is doing at full throttle at high speeds (80+) i dont understand why tho!!!mines been remapped with just a filter.......however it seems theyve installed winows 95 on it coz its hopeless!!
