leon mk1 grille swap?
20v roper
272
hello, im new to this so be gentle with me!! can i swap the 3 grille pieces on my leon on which the slats run horizontally for the honeycomb items seen on other leons?? and is it expensive to do? many thanks.....
RobM
Back from the dead...
Sep 27, 2006
4,982
Southampton
If you have a LCR or an FR+ then this mod doesn't work, as the centre S is a different shape. All other models are fine though :)
Cupraloon
I was going to fit a badgeless grille to my 20VT prefacelift, untill i realised it was a one piece unit and needed to be cut about, and couldn't be bothered with all that... but thats just me.. :redface:
Nov 27, 2006
1,204
www.cardomain.com
The badgeless part isn't, it's just the two side grilles that are one piece (and require bumper removal)
The grille with the S just pops out
Will the outer grills fit a LCR or FR+ ?
Yes. Infact, if you're handy with a dremel (and can be arsed) you can almost make a honeycomb S badge to fit the LCR out of a spare side grille. Have a look around for honeycomb LCR grille...it's been done
