Leon FR (2020) Air conditioning fault?
Oct 15, 2020
Hi guys,
Recently picked up my new Leon (FR 1.5 TSI 150 2020) and I can't figure out if there is an issue or it's just me missing something...
Basically, if I set different temperatures in different climates, either in auto or manual, the car seems to have a mind of its own and pump hot one side and cold the other. Even if the 'hot' side is set to a lower temperature than the 'cold'. Does any of this sound normal behaviour or does it sound like a fault? I've not tried testing the third climate zone (the rear seats).
Any help or other peoples experiences would be greatly appreciated!
dan555
241
95
Just tried in mine and it seems to work correctly, set temperature to hot(hi) on one side and cold(lo) on the other and vice versa both times it was correct. I think it's something that your dealer will need to look at, it doesn't sound right
Oct 15, 2020
What happens when you sync the two climates? That’s where I’m getting the issue I.e both sync’d at 21.0 but after about 5-10 mins one side will blow hot and one cold continuously.
martin j.
1,997
894
Fife
If set on climate does the heater not blow cold air at times to regulate the temp to the figure set, so in effect one side could be heating up whilst the other has reached temp and is being regulated by adding cold?
dan555
241
95
Will try tommorow.
It did adjust the temperature quite quickly, the air it was blowing in about 10 seconds and then noticeable in the cabin after a few mins, however I did try on max fan(7)
Oct 15, 2020
This is what I presumed however, once either side goes hot or cold, it stays like that for the rest of journey. So to me it doesn’t seem like it’s trying to regulate
Oct 15, 2020
Will try tommorow.
Thanks for trying, let me know how it goes!
Oct 17, 2020
Hi, I have the exact same problem. The drivers side blower is always really hot even when the temp is set to 19°C and all the others are cool. It’s getting a bit annoying, I end up turning off that row of blowers. Might contact my dealer on Monday!
Oct 15, 2020
Hi Phil, thanks for sharing your similar issue! It certainly does get annoying! I'm wondering whether its a fault in the 'brain' behind the AC...
dan555
241
95
Managed to test on mine, it seemed to have worked as expected, did the following:
Set the passenger side to lo and drivers to hi, it was in auto 2 but when I changed the temperatures the blower went to full speed.
It was blowing as expected lo on passenger and hi on the driver's side.
Left it for about 5 mins and it worked quite well, the passenger side was very much colder than the drivers.
Set the temperature to 19.5 and synced them.
The blower went back to Auto 2 and the vents on both sides were blowing the same temperature, which felt like 19.5
It didn't seem it was trying to compensate for the temperature difference instead it was blowing the same temperature and letting each side warm-up/cool down naturally
I think if one side is always blowing the same temperature regardless of setting then it could be one of the shutters is stuck in the heating core, or something wrong with the controlling computer.
Oct 15, 2020
Just to follow this thread up for anyone experiencing a similar issue to which I originally had.
I got in touch with SEAT via their driver line service. Explained the issue, got it booked into a local garage and they fixed it within the same day. The engineer told me that apparently this is a known issue and is a fault straight from the factory due to incorrect wiring.
Reactions: Sammybee93
Nov 20, 2023
Hi David - My car has exactly the same issue that you reported but my dealer just reports "No Fault Found" when asked to investigate even though I informed him that I had seen your post on this forum. I realise that it was some time ago now when you had your vehicle fixed but would it be possible for you provide any further details of your contact with driverline, garage, engineer or exact nature of the fault so that I can try to get some action from my dealer.
