Leon Cupra R, Lift off oversteer
steveshady
Back to Deezley Weezly!
Mar 15, 2004
176
Exeter
Afternoon all!
Have had my LCR a few weeks now, absolutely love it! I love the grunt and the noise it makes, awesome! Its mauled an Astra Coupe Turbo, slaughtered several BMWs, and made a complete mess of countless idiot boy racers!
My only concern is the lift off oversteer I get on long fast corners.
Its probably just that i'm used to my Passat which had a heavier back end and softer suspension.
Its not extreme, but a little concerning when I'm taking a fast a-road corner and I have to lift off for slow traffic ahead and the back starts twitching.
I'm getting a bit used to it now by keeping the power level throughout the bend, but there are times where you need to slow down suddenly, and all that momentum on stiff suspension has to shift the weight somewhere!
Would lowering the rear tyre pressure help?
D3DNA
391
Cov
Being in a higher gear round the corner means the revs don't drop as fast when lifting which will help stop the back from twitching.
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
tyre pressures, worn out shocks or dare I say it - driver ability would all contribute to this
my money would be on the rear shocks.
Feel
Veedubya 'velle
Jun 12, 2003
4,918
Midlands
Yeah, avoiding being abrupt is a good idea - but you can't always.
A rear ARB helps a LOT.
YerMother
comes and goes
Sep 22, 2004
1,461
East Midlands Drives: Scirocco GT
Unless your really pushing you shouldn't really get it (presuming it's in the dry)! Although it may feel that the back does want to break away due to the boaty behaviour of the standard suspension set-up!
I would check dampers for any signs of leakage and check your tyre pressures as already said!
Fluke
Lift-off overstear is just something you get with nose-heavy, front engined, front wheel drive cars. You notice it more becuase you are not used to the power. What you actualy have is power understeer - and a car that is designed to feel right that way - that goes away when you lift off. You just have to get used to correcting your steering as you lift off. It becomes automatic.
steveshady
Mar 15, 2004
176
Exeter
Its probably just that I'm pushing it pretty hard because I'm still stoked by it!
General handling is excellent, round sharp corners and windy roads, its just when you're taking a long corner that you can take at 70+ you notice it.
Its not a problem, but could be if I really needed to stop and the back was still eager to keep going!!
I'll get it checked out at my bros garage and if anything needs to be done i'll take it to the dealer.
sportbilly
thinking out loud
Oct 8, 2001
2,386
in my car
Thats why you should have a balanced throttle through corners, but like you said if there is someone in the way and you brake hard on a corner I would think you would get this on most cars.
