Leon Cupra R Brembo's... will they fit?
Dave_R
Save a Sheep...Buy Brembo
Sep 20, 2004
3,666
South Wales
Been thinking of getting some nice 4 pot calipers and was wondering if the Brembo’s from the Leon Cupra R would fit straight onto the Mk2 Ibiza Cupra Sport 16v or will they need brackets made up?
Since the discs are 280mm, I was just thinking of upgrading the calipers and having drilled and grooved discs.
stoneyfordNI
GGG GGG GGGIGITYYY
Jan 9, 2005
2,673
Lisburn NI
brembo cupra R kit is 323mm discs , and 5*100 PCD , ur only 4 stud , so thats a prob , or are u thinking about making the brembos fit ur standard discs, how wide (thick) are ur discs , LCR is 28mm , minimum 26MM
Dave_R
Sep 20, 2004
3,666
South Wales
Was thinking of just the calipers and leaving the standard discs. I know someone who can make up brackets because he usually uses Brembo from Seat's and make the brackets up to fit.
But I was just thinking would they fit onto an Ibiza without making brackets, or did some Mk3 Ibiza's come with Brembo's?
Wasn't sure on the size of the discs on the leon but was looking at my mate's cossie the other day and noticed they were only 283mm and had 4 pot calipers. So if I was to change to Brembo would you recommend changing the discs to?
stoneyfordNI
GGG GGG GGGIGITYYY
Jan 9, 2005
2,673
Lisburn NI
mark 3 cupra R ibiza had brembos , i believe a 305mm disc
ur standard ones are 280mm*22mm (20minimum)
anything like this would be a custom job, mixing and matching parts , surely theres an off the shelf kit u can buy , was it not a golf front end on ur shape of car
Dave_R
Sep 20, 2004
3,666
South Wales
Not too sure, think it's all Golf Mk2 chassis, I know the lower arms are Golf Mk2 but I've heard that the calipers on the Mk2 Ibiza are the same as the Golf VR6 :confused:
Was just thinking that If I could get a second hand set from the newer Ibiza or Leon then it may have worked out a bit cheaper :shrug: Doesn't look it new lol.
Cheers mate! ;)
Nov 2, 2004
9,335
South Wales
Dave just go and have a word with Kitney.
Let me know how much tho coz i'm tempted with a set of brembos or similar for mine.
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
Cheers mate! ;)
ibiza mk3 cupra calipers are same as G60 Corrado.. 280mm brakes same as them.
ibiza cupra r came with brembo's... 305x28 size disk.
minimum wheel clearance of 16" diameter and 38mm caliper clearance req'd tho..
Dave_R
Sep 20, 2004
3,666
South Wales
Haven't seen much of him to ask him and had a word with his old man a while ago back in the summer but he needed to have the car & the calipers for a day or two. He can make them fit just gotta make up brackets but was hoping I wouldn't need them :)
