leon cupra-r brembo gt junior on ibiza cupra 1.8 20vt 2001
black pearl
Newbie
Feb 10, 2006
55
SEAT CUPRA R BREMBO CALIPERS GOLF MK1 MK2 MK3 MK4 AUDI.
These are the Brembo GT Junior calipers and can be made to fit many cars with different mountings brackets. Unlike most brembo calipers these have removable mounts.
INCLUDES CALIPERS, PADS, RETAINING KIT & MOUNTING BRAKETS
These type of calipers can be used to fit golf 1 & 2 and corrado using 280mm & 305mm four stud vag discs.
Also a direct fit to mk4 Golfs if used in conjunction with Leon Cupra R Discs.
there no discs with them..
if i read it look so :confused:
because of the 280 and 305 stud vag....
:confused::confused::confused:
1,204
www.cardomain.com
Ah the old "will fit any car" ads :rolleyes:
These brakes will fit any car ... all you have to do is machine some custom brackets and buy some discs that are the right thickness ... and offset ... or get some custom bells manufactured to suit
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
and you posted LEON CUPRA-R not IBIZA-R
There's more than one SEAT R model is'nt there.
Ibiza Cupra-R (mk3) are GT Junior Brembo's, and yes if you get the rest of the right hardware to suit they will mount onto the 305mm disks etc
Leon ones have different offset, and I am not aware of an available brkt to suit. you can make anything if you have the resource and skills tho.
pj1985
1.8T Power
Oct 31, 2006
2,218
Hampshire/Surrey
If they are IBIZA cupra R then they will fit. If they are LEON cupra R then they will also fit if you get some custom stuff made. Also no where in that add does it say what car they are from.
black pearl
Newbie
Feb 10, 2006
55
there from a leon cupra-r. it's a brembo gt junior kit for the leon cupra-r..
and it says this :
These type of calipers can be used to fit golf 1 & 2 and corrado using 280mm & 305mm four stud vag discs...
so the calipers must fit if i have the right brackets...
and the corrado has 280 or 305 mm and the ibiza cupra-r also normal 305 mm so then it must also fit on an ibiza cupra 1.8 20vt 2001.. ???
freddie
super duper cupra...
Apr 2, 2007
350
Hull, East Yorkshire
the conversion was done by my best mates father, i havent got a pic to hand of my brakes as im in work, but can show u a link to his business
http://www.godspeedbrakes.co.uk/
he can pritty much make waht you want,
i think his prices have come down now so better off phoning for details
Cool, but why not buy the GT kit to suit the bezza £740 rather than go custom way round meaning everything costs that little more?
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
and it says this :
It wont be GT Junior kit...... LCR caliper have two bleed nipples and no external balance pipe at the bottom, and as said different offset to the GT junior caliper (aka ibiza-R caliper)
If its got one bleed nipple and no rear external balance pipe then chances are its an ibiza-r caliper and then happy days... seat stuff fits it for 305mm disks.
280mm disks are NOT correct, they're too thin. max pad wear+too thin a disk (22mm not 28mm) then pistons are overextended. Your life!
black pearl
Newbie
Feb 10, 2006
55
here some photo's :
