Leon Cupra oil consumption
H Rafiq
1,136
470
Leon Cupra 280 2015 DSG, 118,500 miles at the moment. Had a service 18th Nov, inc oil change n filter, sparks, air n pollen filter n inspection etc. No engine oil leaks. Now the ‘check oil’ light has illuminated. Is this normal consumption? It’s been 6 weeks…
SRGTD
2,592
1,434
Was the oil level at the maximum mark on the dipstick immediately after the service? I’ve been given short measure on oil before when my car was serviced (only just above the min mark on the dipstick).
How many miles have you covered since the service on 18th November and how does that compare to the mileage normally driven between oil top-ups prior to the service?
H Rafiq
1,136
470
Same mileage, no difference. Not many miles at all. Just used around town, that’s it. I assume it was filled to the brim to be honest, but can’t be 100% certain. I’ll fill it to the max myself this time, and see how long it lasts.
TheJudge2009
18
Ireland
Unless you drove (12,00/15,000 mls) it should not come on, it might come on if you go very fast around a bend or roundabout).
As you said fill it to the proper lvl and see how far you get, just be carefull dough.....
Happy New Year.....:giggle::giggle::giggle:
DEAN0
Old Git
Feb 1, 2006
5,370
355
Preston - UK
Just a thought - how much oil is showing on your service invoice ?
My lad had his car serviced and there was only 5ltr showing on the invoice.
This meant that there was 0.7ltr short so his car was not far above the min on the dipstick after the oil change.
H Rafiq
1,136
470
I supplied my own oil n parts etc, the garage just did the labour part of the service. The oil cans up in the loft now, far away… But they definitely used >5L of oil.
tracktoy
636
461
have you checked the dip stick to see what the level is and have you run a scan to see if anything odd is reported.
H Rafiq
1,136
470
Checked the dipstick. It’s halfway between min n max, thankfully. Must’ve gone round a corner fast or something. Put 500mL in anyway for now.
Reactions: tracktoy
