Leon Cupra Alignment Specs
  • Thread starter Deleted member 43482
  • Start date
Hi guys,
Does anyone have a link to somewhere that states the SEAT geometry alignment specs for a mk2 Leon Cupra pre FL?
Stuart
Thanks Springer that would be awesome if you get a chance!
springer
256
Would you have the information on the Leon Sport? Just had mine done on a full Hunter jig and wanted to compare to Seat spec if poss. Cheers :)
Hunter get their measurments from manufacturers so yours will be set to Seat spec
springer
256
If you look between the cupra and cupra R there is a slight difference(more neg camber on front and less on the rear).Seat must have thought it was better during testing,wether we would tell probably not.
