Leon 2.0 tsi 190 dipstick snapped!
Athlon
7
Just a heads up, Just went to check the oil after a quick run home and the tip of the dipstick just came apart! It has snapped just on the first kink, the 'full' mark.
I was lucky it came off as I wiped it and not in the sump. So maybe be careful/check yours is not weak in that area next time you check your oil.
I don't suppose anyone has the part number do they?? Cheers.
serdar_18fr
374
Is your car's engine code DKZA?
If it is, then the part number of the oil dipstick should be 06K115611B
Reactions: Athlon
serdar_18fr
374
Brilliant! Thank you very much.
Well worth checking if you have this engine just in case.
Wish I had. Engine displacements bigger than 1.6 liters are taxed very heavily in my country, so most of us have to make do with smaller ones, like my 1.4/125hp engine. Anyway, I have no complaints and I'm happy with it :)
Sent from my 23013PC75G using Tapatalk
