left foot braking...
helms
Console Race Car Driver
Jan 30, 2005
492
Basingstoke
In the MK3....
It doesnt work!!
You cant keep the revs up and left foot brake, as the engine just dies and when i take ur foot off to re accelerate it take a good second before the car realises.
The whole point of left foot braking is too keep the revs up to get a better exit on the corner, but it does the opposite with the beeza..
Wont be doing that again! :whistle::headhurt::redface:
DodgyDave
121
Glasgow, Scotland
Dont know about the beeza's but in the Leon it's the ECU that cuts power to the engine when you brake for more than 1/2 a second.
Tried it a few times but just wont work!!! - would have been handy for track use as well :)
Dave
In the MK3....
WRONG
Thats only in rear wheel drive cars. In front wheel drive cars its to counter understear.
I hope this helps:
"Left Foot Braking
In Front Wheel Drive
Theory:
When driven under acceleration with no brakes applied, a front wheel drive car will understeer when the front wheels are turned. To overcome the understeer, a technique called left foot braking is used to change brake bias (balance) to the rear. By using a combination of throttle and brake you can change from understeer to neutralsteer to oversteer. How does it work? Read on!
Weight Transfer:
Think about this for a second. When you stand on the throttle, which way does your body try to go? Toward the rear wheels! Right? Now what happens when you brake? Your body tried to go forward! This boys and girls is weight transfer! By using the basic rules of weight transfer and a combination of throttle and left foot braking, you can be in control when the unexpected happens on a rally (which always happens)
How Does It Work?
Brake bias in normal street cars is toward the front wheels for safety reasons. If you have ever pulled up your hand brake when turning on a wet road and spun out, you know why they build cars this way. What you did was bias the brakes to the rear, and this is not what Grandma wants in her Buick coming home from the supermarket. But as rally drivers we can use a means of biasing the brakes to the rear. Some of the things that can be done include using a brake bias control valve or installing more powerful brakes on the rear wheels. That works wonderful on a track, but on a rally it's hard to change your brake bias in the middle of a turn that suddenly changes from dry dirt with good grip, to wet slime with no grip.
Enter Left Foot Braking!
Once your have mastered LFB, when the road surface changes, you can change the brake bias by either adding power or brake pressure ( this is also called "modulating"). Example: You are in a turn and the rear of the car starts to slide out more then you want. You could release some brake pressure and increase the throttle. This will change the oversteer to understeer. The reverse is also true. If the turn tightened, you can change to oversteer by increasing brake pressure against the throttle. Also by balancing the brake and throttle you can get a neutralsteer.
Why Does It Work?
A tire has 100% of it's possible traction when it is rolling straight with no braking or acceleration. When you change any of these factors the tires affected will have less available traction and break loose earlier.By applying brake against the throttle in a front wheel drive car, two things happen. One: The front wheels keep turning. And two: The rear wheels try to lock up. If you are in a turn, the back of the car will start to slide toward the outside of the turn. To control or stop the slide, apply less brake and more power ( this changes the oversteer toward understeer and stops the rear wheels from sliding toward the outside of the turn ).
Putting Theory Into Practice:
Let's Give It A Try: Now comes the fun part, driving the car. Find a safe place to practice, a gravel parking lot with no trees will do.( If you live up north and it's Winter, try a frozen lake, this is ideal because everything happens at low speed ). Set up some traffic cones to make a Tee intersection. Now get in your car and practice driving the turn without left foot braking, but try doing the normal braking with your left foot.(What did he say??) Yes, try braking with your left foot! You can't learn to LFB until you train your left leg to brake! If you have never tried using your left leg, your will find it's like trying to write with your left hand if you are right handed. This is very important. Until you can drive doing the braking with your left leg, you can't do LFB. Once you can brake with your left leg, now let's try something new. First think about what you want to do, then start your practice turn. After turning in, apply the brake against the throttle. If you did it right you should feel the rear of the car start to slide to the outside of the turn. When you are pointing in the direction you want to go, let pressure off the brakes and increase the throttle. If you did it right you will be amazed at how the car seemed to pivot on the front wheels. So wipe the silly grin off you face and try it again, and again, until you can start or stop the slide at will. Congratulations, you now know what LFB is!
Practice Makes Perfect:
The first few times you try the exercise above, you will probably find the car slowing down in the turn but not much else. Try using less brake. You will be amazed at how little pressure is needed. Also remember to turn in before you apply the brake.I don't mean try to turn before you have slowed down for the turn, I'm talking about after you have braked and selected the proper gear for the turn, you must let some pressure off the brakes before turning in.After you get bored with just making a left or right, try setting up an "S" turn and play with that until you can keep up your speed through both turns. Remember to treat each turn separate, and lift off the brake and turn in each time. When you have mastered Left Foot Braking you will find that you will have control of your car like you never thought possible! It's both faster and more important safer. So don't get discouraged if it seems impossible to master, keep trying and all of a sudden it will seem easy!"
Adam R
Diesel ISN'T a Dirty word
Mar 5, 2007
2,851
lee in the solent
i tried this LFB last night and omg :eek: i hate it, the ibiza seems like it is hitting a brick wall after about 1 second on the break, then trying to put the foot down, no responce for the a good second or so after. it seems like there is a bit of coding in the ECU that shuts off engine power if your breaking and accelerating at the same time.
well for me im sticking to down shifting.
helms
Jan 30, 2005
492
Basingstoke
Jamin Berry, what you have posted is correct, but that is only applicable MID CORNER.
Heres my senario, in 3rd gear aproaching a corner, fairly sharp, need to be taken in 2nd, mid revs.
Heal-tow it on the way in as braking with right foot, then switch to left to continue to slow down, and gently hold right foot on accelerator to hold revs up and stop turbo dieing off.
once slowed down sufficiently for corner, release brake from left foot and accelerate, should you encounter and understeer, gently touch brake again with left foot to bring in understeer.
How it really works....
Heal-tow it on the way in as braking with right foot, (not really noticing that nothing has even happened when you tried to blop the throttle) then switch to left to continue to slow down, and gently hold right foot on accelerator to hold revs up and stop turbo dieing off. (resulting in suddenly standing the car on its nose as the engine dies and you brake FAR quicker than expected)
once slowed down sufficiently for corner, release brake from left foot and accelerate, (at this point ur doing 3mph and ur car seems like its about to stall!) should you encounter and understeer (no chance of that when im doing 5mph by mid corner!), gently touch brake again with left foot to bring in understeer. (as said.... pointless)
NowGottaIbizaMk5
375
Beverley
I hope that Helms suggestion of "Heal-tow it on the... " is a typing error!
Towing a car while braking in such a manner is very dangerous.
I suggest that heal-toe is better and safer my friends.
