LED indicators
mattsutton
Hi,
Just had a set of LED replacement bulbs delivered for my rear indicators, fitted one to test them without any problem, put the hazards on, and the LED bulb works perfectly for about 5-10 seconds then just... stops.
If you turn the hazards off and on again the same thing happens...
Anyone got any ideas whats goin on?!
Cupramax
Uber pimp meister
Aug 1, 2001
3,977
All VAG cars use a load sensing system to detect bulb failure. LED bulbs dont place enough load on the system so they dont work properly. I think you'll need to put a resistor inline on them or something similar to produce the same load as a conventional bulb.
mattsutton
oh arse. I was hoping that wasnt gonna be the case..
Back to ebay it is then!
