LED brake lights VCDS coding
Feb 12, 2022
Hallo
Anyone got their brake lights to flash both outer and inner on the tailgate?
Also other coding / adaptations that’s a must to do?
Seat Leon FR 2016 - with LED
black_sheep
1,255
587
Do you mean flashing under emergency braking? Or something else? If the former, then this is standard.
This is my go to site for things to consider:
Feb 12, 2022
No not flashing. When the brake light are activated under normal circumstances and the light switch is in Auto, only the outer LED near the edge is activated
black_sheep
1,255
587
Ok.
This thread lists the codes for each of the light positions and is probably has some additional information.
Feb 12, 2022
Ok.
Thanks for the quick help and fast answering. I will look into it and hopefully learn by doing.
