My LCR started having a misfire between 2500 and 3500 when on wide open throttle. Tried resetting ECU, aligning throttle body, changed the type of petrol but no luck on sorting it out. It almost sounds like it is running on 3 cylinders till it clears 3500 Rpm then runs fine. It seems at max boost is when the misfire happens. Anyone got any ideas ?
