lcr turbo outlet hose
wayne lcr
bored of it now
Mar 5, 2009
4,548
doncaster
any 1 changed the 90 degrees pipe between the charge pipe and turbo.if you have have you noticed any difference.cos i was looking today and its very poor and can be pushed in very easy:(
Ronin225
4,652
22
Worcester
I have one, no difference in power or response or the like but is much stronger
It is a special high temperature silicone so if you get one made make sure it can take the temps
Mine was done as a preventative item as already had OEM pipes fail including TIP
Ronin225
4,652
22
Worcester
It is not a performance upgrade it is for reliability
Had OE pipes fail and hence replacing as much as possible
Looking to go hybrid (eventually) as well so higher temps and older pipes = failure
Dani_b19
301
Because comparing the oem and forge one, there was no difference, both are squidgy and press in etc, the only difference is the forge one is newer and had tobe cut down.
Personaly buy a 90" elbow off ebay if you have to.
wayne lcr
bored of it now
Mar 5, 2009
4,548
doncaster
yea theres a place in doncaster just down the road and he said 15 quid to me so going tomoz to get it cos the oem is pants and its 1 less pipe to worry about
Feel
Veedubya 'velle
Jun 12, 2003
4,918
Midlands
Not sure a standard item will stand up to the temperature over time, plus the stock one's not exactly 90'.
Your choice, but I think it's one of those cases where you buy cheap and buy twice.
I'd rather leave the stock one on than replace with a standard elbow.
