I'm slowly getting all the parts for the GTRS conversion and hence I need to get the LCR/S3 etc... TIP.
I was thinking, I won't be abel to fit it to my exisiting KO3s and Maf housing as it will be slightly larger..... so it won't be able to go on until I get the full conversion done...... bummer....
However, what if I did want to fit it.... Is there a way I could theoretically "line" the Maf housing outlet and compressor inlet to slightly increase the diameter so that I could use the TIP straight away without it having to lie around for months until I get all the bits?
Cheers for the advice in advance chaps.
Raf
Raf
