LCR squeaking brakes!!!!!
pigginell
Car has been back several times to have the squeaking brakes repaired they have fitted new front disks and pads removed and cleaned the rear but they still squeak like a f*cker, Have been informed that they know of a fault with them rattling and they have tried to say it is partly to do with this (sorry not convinced)
has anyone else had this problem and did they manage to sort it ??
Squeaking brake = F*cking anoying
Pete
bentaw
Revo'd LCR
Oct 1, 2004
1,067
Hampshire
my brakes are doing the same dont know what is wrong with them but they really get on my t*#s anyone got any ideas
CHRIS200
Powered by Seat Sport
Oct 4, 2003
388
Fleet, Hants
I had this badly, put it down to worn out discs and pads. But continues very slightly on new discs and pads. Spoke to Seat both this and they recommended removing the pads and putting a light coat of copper grease on the back and edge of the pads and on the retaining bracket and pins. Gonna do this at some point and see if it makes a difference. Sounds sensible....??
luke
229
Hants
This is a "feature" of the LCR. ;)
Copper grease apparently works.
btw: If you remap your car please send some vids vs the D3 :D
Deleted member 7659
Our rears are terrible when reversing! Car's done just over 3k from new and it's getting worse. I know 'they all do it' so haven't bothered raising it with the dealer as yet. If it gets any worse I will, otherwise it can wait till the first service.
I'm pretty light on brakes, so I know I haven't cooked them!
Adrian
warren_cox
Back from the dead
Adrian
Ditto, have tried braking harder to clean them up and no joy. My 05 plate is much worse than the 53 plate I used to have for this issue. They are also much worse when reversing after they have been used. Cold they are obvioulsly unheated. Keep meaning to whip them out but can't help feeling on a new car I shouldn't have to :censored: :censored: What's worse is it seems to be getting louder all the time.
Deleted member 7659
Sounds like yours is exactly the same as mine! My wife drives off to work in the morning and wakes the dead backing out of our parking space.....and that is just the back brakes, before anyone makes any other suggestions :)
Ours seem better when warm - the noise isn't quite as piercing at least.
I thought they'd 'fixed' this on later cars from the factory? Mine only came off the line in January/early Feb and was registered in late April so it's not old stock
Adrian
dontnoanything
dontnoanything
Jul 19, 2005
135
gondor
there are modified hand brake cable brakets with dampers on for the noise on the rear brakes when reversing on leons and ibiza mk 4. the dealers should no about them. ive been fitting them for about 6 months tell the dealers to read there hst book
CH1
503
Adrian
I've got exactly the same thing on my 05 FR and I've only done 1.5k and it seems to be getting worse -in reverse and the brakes squeal. My car was inspected (PDI) in UK Dec 2004, registered June 05. Dont know if that 5+ month gap did any harm..? Though it should be getting better not worse.
Scotty_b
Leon Cupra 300R
Jun 3, 2004
6,026
66
Hertfordshire
Two of my local dealers insist that theres no info from seat (but i dont trust them). Have you got a refernce number for this document or a copy of it so a can wave it in there face?
Ant FR
2,861
Kent
My Brembo's sqeak lie a bitch, however i feel it may be cos i cooked em at the nurburgring, so new discs and pads maybe needed soon. Still the best brakes money can buy in my opinion and if it means i have a little squeaking to put up with then so be it.
Jun 28, 2001
1,533
seen this alot normally down to glazing of the pads and discs(driving like a fanny)
good hard braking followed by power wash does the job
pigginell
This is what I was given to explian my squeaking brakes..... Strange it dosnt mention squeaking
Hope this helps
dontnoanything
dontnoanything
Jul 19, 2005
135
gondor
cant help with the front brakes but ill get the part number for the handbrake cable modification if it helps. but the dealers should realy read ther hst book
Charlie Br0wn
Although my rear brakes squeak a little when pulling to a stop going forwads, the main problem for me is when reversing. Has anyone got one of these handbrake cables to fix the fault?
"Its because the pads dont have anti-squeal pads" - Can you get these for the LCR??
