lcr sounds a bit rough!!!!
street_sleeper
when i was driving home the other night my car suddently started juddering and wudnt really go over 2500k in any gear, thought my car had gone in limp mode???? anyone?
and the emmissions light on my dash would flash inconsistently!
the light was on permanently before due to having a panel filter fitted i suppose!
when i got home i thought the maf might of been faulty???? yet again anyone?
also found a split in a small bore hose that goes to my tip!
revoved my 007p and replaced with oem!
but since getting it home and changing the maf, repairing the hose and changing the dv it sounds like its tapping and still wont run right!
also its slightly overdue a service? could that be the ecu shutting down?
jus would like some general advice or if you have had the same problem?
Note ive got vag com on the way also!
cheers lee
dicko's
350bhp IHI Ibiza
Aug 5, 2008
240
Hartlepool
my guess is a failed coilpack mate just start the car and let it idle and unplug the coils 1 at a time,you should here the engine get worse and them apart from the failed one
street_sleeper
was coil pak number 4, the one under all the pipes! gud fun! lol
