LCR SMOKING ON IDLE again
D8MNS
Quattro Power baby yer!!!
Nov 8, 2004
618
Badland Brum on the manor.!!!!
right i had this episode before and came back again, on my 2nd( new engine )also its only covered 7 k on new engine
any ways took it to the dealers they then changed the valve stem seals as they thought it was the course of the smoking stop for about 10 days then slowly started again
so im wondering what it could be as its due an mot and didnt pass on emmisions wen it got tested as he said theres oil in it being burned
any help please as im getting no were fast and need it back to normal cheers :help:
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
oil in exahust still?
turbo seals ok?
breather system ok?
compression test and or leak down may show wear on rings perhaps.
surprised at guides/seals on a new engine.
D8MNS
Nov 8, 2004
618
booked in to dealers next monday
NeilC said:
You taken it back to the dealer yet? What did they think?
but last time they replaced the stem seals thats all i know so is there anything else i can tell them...
bill would there be enough wear on a new or recon engine thats just covered 7k ??? in your eyes do you think its possible :(
D8MNS
Nov 8, 2004
618
its hardly even noticable the loss i think..
keep checking the oil but doesnt seem to be using much not noticing a noticable drop of oil on the dipstick ... at all could say how much over a thousand miles will start checking a lot more now tho :headhurt:
D8MNS
Nov 8, 2004
618
only smokes
Si said:
You sure is really blue smoke? Not just black or grey with a hint of blue.
Does it smoke on full chat and full boost?
Is it only on startup?
Smokes on Idle cold or warm?
no smoke on full chat or any type of driving speed
only stars on say on cool down time for turbo as if the turbo is using oil to cool down and this is being pushed thru the exhaust system its only very noticable blue smoke no black grey white smoke at all doesnt do it wen cold either that ive noticed so is only happening wen warm and is very very blue smoke ////????:doh:
jonathanp
736
Coventry
damian your not having much luck hey, your aux pump working ok after you switch the engine off?
you checked for any fault codes?
D8MNS
Nov 8, 2004
618
need a check for codes mate yuoll ave to pop by , and the aux is still working i think ,will ave to ave a check listen aftre i switch her off , would this cause it tho if it was not working ???
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
wear in 7K?
unless its not had oil in it I dont see why it would have worn so badly in such low mileage no. :no:
turbo ok?
D8MNS
Nov 8, 2004
618
turbo & thanks so far ........
Si said:
Sounds more like a turbo problem than an engine issue.
100% sure they changed the turbo too?
If the AUX pump isn't working that it no good for the turbo as they are cooled down by it.
pretty sure the aux is working fine as it does the smoking wen the aux seems wen cooling the turbo down if that makes sence , im thinking it is a turbo seal problem
to bill yes engine has got oil in ,,, other wise id ave no smoke .:p ...had a brain storm take oil out no smoke but not sure how long the engine will last lol.:whistle: ..
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
they must believe its a cylinder/piston related thing.
i have heard of the plating on the rings to fail on some...
D8MNS
Nov 8, 2004
618
cheers bill ........
wouldnt of thought this was possible if it was a new engine just my luck to get a bad egg oh well hope everything is sorted ,
only bad thing now is the stealers want me to pay 10 hours labour £600+ :help: should i be ringing seat uk about this as it was a problem before the warranty ran out that they was aware of (out of warranty now tho):cry:
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
assuming the new parts were fitted within the last 12 months, they're still within their own warrantee
