lcr Relocation pipe NOISE
Mar 3, 2008
807
sunny Devon
hi people
im thinking of buy a forge relocation d/v kit for my lcr,i have d/v simlar to the forge007.
at the moment i have a 57i k&n fitted and the recirclating d/v gives a lovely echo from the induction kit... (love this sound?:p
what i want to no is if i buy the relocation kit?
will moving the d/v change the sound? ie make it less noise ?
or will the sound level stay the same? meaning i get that lovely echo whoosh?
please help???????????????:confused:
Ronin225
4,652
22
Worcester
I have the relocation kit with a 007 and a green panel filter.
Inside with windows up you can hear the air rush through the extended pipework just as loud but a slightly different noise.
But with passenger window down it seems more audible outside the car.
Some people slate relocation kits but i have no leaks and the valve is touchable after driving, looks good too
dav3
devilishd4ve xbox tag
Mar 29, 2007
655
Essex
I've got the relocation kit with the forge splitter-R and it has if anything made it sound louder. Not sure on whether it made car smoother as the clutch was on its way out when I fitted it so couldn't really give it a good test. But seems to be fine now clutch has been replaced
Ronin225
4,652
22
Worcester
Spool seems the same throttle response better but this was done at the same time as N249 bypass so cant really tell if or by how much
